HELP ... What Is The Best Way to Achieve Load Balancing??
Hi Guys ..
HELP … What Is The Best Way to Achieve Load Balancing With More Than three OR More Lines ??
Please I Need a Quick And Simple Explanation ////@“”@\\
http://wiki.mikrotik.com/wiki/Manual:PCC
There is no quick and simple in advanced networking.
seeing so many post about LoadBalancing, i think it’s time for MT to develop simple config option similar to /interface bridge for LB, preferably with 0 (zero) configuration parameters, just list of interfaces to balance over. Seems that “Search” in forum or in wiki is completely useless … :frowning:
Hi again guys .. . .
we all know that with load balancing if we used an unlimited account and we started a download we will receive the maximum download rate for one of the main gateways .. Right ??
in other way .. any single download request with an unlimited account will have the the maximum download rate for one main gateways .. SO if we have three gateways with 2M download rate .. our first download rate will be ONLY 2M , and then if we requested another download at the same time with previous one we will get another 2M ..
THE Question is that >>
is there any way make the first download rate for the unlimited user equals the three gateways ?
like , if we have three gateways with 2M download rate .. we should have 6M download rate for the first request ??
In short: no.
Not unless you have your own IP space and have a specific BGP setup with the provider, in which case you are not reading this thread.
