Greetings to all,
I’m new to this forum & as well as to MikroTik products.
I wanted to setup a WISP network by using PPPOE authentication method for my end-users.
I already got around 25 end-users.
Is there any MikroTik product which I can use to setup PPPOE authentication & to limit the bandwidth to end-user by their “username”??
Suggetion and Guidance highly appreciated.
Thanks,
BoKa
You can that with all the routerboards.
Choose a cloud core router if you have a lot of clients want to serve. Read above 100 simultaneous clients.
RB2011 series are good for lighter work
Hi Plisken, Thanks for reply.
I don’t need any WiFi features.
My clients list will NOT cross 60.
Clients Bandwidth speed will varies from 1Mbps to 4Mbps.
Based on Client’s Username, I wanted to set limit for bandwidth usage (Example: 4Mbps speed upto 100GB then speed will reduce to 1Mbps till his billing period ends(30days)).
Can you please clarify my doubts:
- Is all RouterBoard includes same features(since they use same RouterOS)?
- Is RouterBOARD can alone handle all my requirements(i.e.PPPoE authentication, assigning static/dynamic IP, Limit bandwidth/speed & log his connect/disconnect timings alongwith session bandwidth usage…etc..)? OR is it necessary to put any Server alongwith RouterBoard?
- Is RB750GL fulfill my requirement?
Thanks in Advance.
BoKa
