dear sir,
help me please …
im trying hotspot login .. but this problem make sure there is asufficient amount of free IP addresses in IP pool
why ??? help me please
dear sir,
help me please …
It sounds to me that the address pool set up for the hotspot has an error in the range stated. Find it in winbox by going to IP/POOL
“10.10.63.200-10.10.63.250” is an example of an entry that sets 51 IP’s for use by hotspot. The actual IP range you use has to reflect the IP scheme (subnet) you are using on your router.
Hope this helps.
