Hi, I have an RB2011 (routeros 6.41) with two ISP: 1 is Cable (primary, 25MB always running) and another is pppoe but managed by ISP modem (secondary 3MB, using it just as backup) *
I have a problem with only 1 website: http://186.153.139.115/siat/gde/AdministrarAuthClaveTramite.do?method=inicializar
It’s a town site for taxes and such.
I can ping and traceroute (second and third hops are failing)
I can’t access, I get ERR_CONNECTION_TIMED_OUT on Chrome
Why do you think it’s your fault IF it’s only this one web site?
It’s normal that certain hops on a traceroute don’t respond. Not all ISPs reply to that.
As for your filter, taken out of context, it doesn’t tell us anything. But if your fw is properly built, you shouldn’t need it. You normally accept return forward traffic that’s "established"or “related”.
Have you tried from another network to see if the site responds?
Thanks Alain.
This site is part of town government. All citizen can access through main site: http://www.parana1.com.ar/afim/ (under SIAT, opens a new tab)
Oddly I can access from same ISP (different service 8MB) and other ISP. I can access from my home. Any time. So, that IP is online always.
I’ll post firewall rules(I’m not there right now), but they’re ok… I think.
Something really, really, REALLY ODD is happening.
Connected to Wifi, from my Android phone using Chrome App I CAN ACCESS this f***ing site.
But I can’t access from any laptop Linux/Chromium; Linux/Firefox; Windows/Chrome; Windows/Firefox; Windows/Edge; Windows/IExplorer; neither from a wired server.
Upgrade Ros to 6.41.1.
6.41 has bugs with pppoe mss connection.
*) ppp - fixed change-mss functionality in some specific traffic (introduced in v6.41);
But earlier you said you could access the website from your phone on wifi?
Might have to dig a bit deeper in your config before throwing the problem to ISP
@CZFan Yeah… but I can access ONLY from my phone (a Xiaomi Redmi Note 4).
Can’t access from any other device (laptops, PC or phones of any brand)
I have a very basic config on a really simple network (10.0.0.0/24 with 54 devices), no vlans, posted firewall rules.
The website started to fail in january, coincidentally after I upgraded firmware to 6.41.
But If everything works as expected except THAT website and apparently the culprit is THAT website
I just could “fix it” using an anonymous proxy extension for browser.
You see, it’s just one person in whole company that access that website and once per month.
I think it’s not worth it if I can solve it in another way.
If I start to register any other issue, then yes, it would dig deeper or maybe make a fresh config.
