So i have something like: AP1, AP2, AP3, AP4, AP5, AP6, AP7, AP8.
AP3, AP5, AP6, AP7 - working like a charm. All ok: poe, etc.
AP1, AP2, AP4, AP8 - imagine im pluggin AP8 in switch. all ok. then i try plug AP1: AP8 imediately dies, AP1 follows - continuos amber color on switch’s POE led indicator. Same goes with any other of this 4 APs. AP2 in, all ok. Try AP4 - boom, ap2 dies, same ap4. Any other possible combination between those 4 same results: POE failure.
Is it possible that faulty wiring to cause such problems?
If yes, how come that INDIVIDUALLY they work?!
Is it possible that Allied Telesis 8000S/24 POE switch to have limitation on power output and only 5 aps can work at the time?
Any suggestions?!
