Help with 802.11n link setup
Hello everybody. sorry for my bad english.
The problem is making the 11n mode link.
My hardware (more information in urls):
2 x dish antennas http://shop.nag.ru/catalog/item/01780
2 x panel antennas http://www.nix.ru/autocatalog/wireless_multico/Multico_APV014_14dBi_72870.html
On each side we have 1 dish and 1 panel antennas.
2 x Routers (RB/411AH)+(R52n).
When I set the 802.11g mode the link working perfectly. I have ~100% ccq on each side.
But when I set the 802.11n mode the link connecting on 300Mbps HT rate and it’s dropping to 54Mbps when the data is start transfering on the link. Moreover i get ~60% ccq.
Configuration sideA:
/interface wireless
set 0 ack-timeout=36 adaptive-noise-immunity=none allow-sharedkey=no \
    antenna-gain=0 area="" arp=enabled band=2.4ghz-onlyg basic-rates-a/g=\
    6Mbps,54Mbps basic-rates-b=1Mbps comment="" compression=no country=\
    no_country_set default-ap-tx-limit=0 default-authentication=yes \
    default-client-tx-limit=0 default-forwarding=yes dfs-mode=none \
    disable-running-check=no disabled=no disconnect-timeout=3s frame-lifetime=0 \
    frequency=2382 frequency-mode=superchannel frequency-offset=0 hide-ssid=no \
    ht-ampdu-priorities=0,1,2,3,4,5,6,7 ht-amsdu-limit=8192 ht-amsdu-threshold=\
    8192 ht-basic-mcs=mcs-0 ht-extension-channel=above-control \
    ht-guard-interval=any ht-rxchains=1 ht-supported-mcs=mcs-0,mcs-1,mcs-2,mcs-3 \
    ht-txchains=1 hw-fragmentation-threshold=disabled hw-protection-mode=none \
    hw-protection-threshold=0 hw-retries=4 l2mtu=2290 mac-address=\
    00:0C:42:61:76:23 max-station-count=2007 mode=bridge mtu=1500 name=wlan \
    on-fail-retry-time=100ms periodic-calibration=disabled \
    periodic-calibration-interval=60 preamble-mode=both proprietary-extensions=\
    post-2.9.25 radio-name=000C42617623 rate-set=default scan-list=2382 \
    security-profile=default ssid=MikroTik station-bridge-clone-mac=\
    00:00:00:00:00:00 supported-rates-a/g=6Mbps,54Mbps supported-rates-b=\
    1Mbps,2Mbps,5.5Mbps,11Mbps tx-power-mode=default update-stats-interval=\
    disabled wds-cost-range=50-150 wds-default-bridge=bridge wds-default-cost=\
    100 wds-ignore-ssid=no wds-mode=static wmm-support=enabled
Configuration sideB:
/interface wireless
    disable-running-check=no disabled=no disconnect-timeout=3s \
    frame-lifetime=0 frequency=2382 frequency-mode=superchannel \
    frequency-offset=0 hide-ssid=no ht-ampdu-priorities=0,1,2,3,4,5,6,7 \
    ht-amsdu-limit=8192 ht-amsdu-threshold=8192 ht-basic-mcs=\
    mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7 ht-extension-channel=\
    above-control ht-guard-interval=any ht-rxchains=1 ht-supported-mcs=\
    mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7 ht-txchains=1 \
    00:0C:42:61:75:75 max-station-count=2007 mode=station-wds mtu=1500 name=\
    wlan-0.161 on-fail-retry-time=100ms periodic-calibration=disabled \
    periodic-calibration-interval=60 preamble-mode=both \
    proprietary-extensions=post-2.9.25 radio-name=000C42617575 rate-set=\
    default scan-list=2382 security-profile=default ssid=MikroTik \
    station-bridge-clone-mac=00:00:00:00:00:00 supported-rates-a/g=\
    6Mbps,54Mbps supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps tx-power-mode=\
    default update-stats-interval=disabled wds-cost-range=50-150 \
    wds-default-bridge=bridge wds-default-cost=100 wds-ignore-ssid=no \
    wds-mode=dynamic wmm-support=enabled
What the problem can be?
I have same problem.
Tested 4.17. 5.6, 5.6, 5.7
I need transparent bridge and when BRIDGE–> CLIENT BRIDGE is used, link ranged 300/300 fall to 54/54 in few seconds/mins.
If i use BRIDGE–> CLIENT PSEUDOBRIDGE or AP BRIDGE–> CLIENT PSEUDOBRIDGE everything is OK, but bridge is not enought transparent as should be for my usage.
IS THIS A BUG ???
One antenna is horizontal and other vertical polarization?
Use station-bridge mode.
Upgrade to latest RouterOS version. Try out Nstreme or Nv2 wireless protocols.
Both antenas are MIMO, perfectly pointed by laser and water level. Distance is 3km.
CLIENT BRIDGE is of course STATION BRIDGE, my mistake. Bad written.
In this setup example you have the band=2.4GHz Onlyg - try specifying wireless N only in your profile.
Are you encrypting your link with ? If so be sure to use WPA2-PSK and AES not WPA or TKIP as this will stop speeds higher than 54Mbps
/interface wireless
set 0 adaptive-noise-immunity=none allow-sharedkey=no antenna-gain=0 area=“”
arp=enabled band=5ghz-onlyn basic-rates-a/g=6Mbps bridge-mode=enabled
channel-width=20/40mhz-ht-above compression=no country=no_country_set
default-ap-tx-limit=0 default-authentication=yes default-client-tx-limit=
0 default-forwarding=yes dfs-mode=none disable-running-check=no disabled=
no disconnect-timeout=3s distance=dynamic frame-lifetime=0 frequency=5180
frequency-mode=manual-txpower frequency-offset=0 hide-ssid=no
ht-ampdu-priorities=0 ht-amsdu-limit=8192 ht-amsdu-threshold=8192
ht-basic-mcs=mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7
ht-guard-interval=any ht-rxchains=0,1 ht-supported-mcs=“mcs-0,mcs-1,mcs-2,
mcs-3,mcs-4,mcs-5,mcs-6,mcs-7,mcs-8,mcs-9,mcs-10,mcs-11,mcs-12,mcs-13,mcs-
14,mcs-15” ht-txchains=0,1 hw-fragmentation-threshold=disabled
hw-protection-mode=none hw-protection-threshold=0 hw-retries=9 l2mtu=2290
mac-address=00:0x:xx:xx:xx:xx max-station-count=2007 mode=station-wds
mtu=1500 name=wlan1 noise-floor-threshold=default nv2-cell-radius=30
nv2-noise-floor-offset=default nv2-preshared-key=XXXXXXX nv2-qos=
default nv2-queue-count=2 nv2-security=enabled on-fail-retry-time=200ms
periodic-calibration=default periodic-calibration-interval=60
preamble-mode=both proprietary-extensions=post-2.9.25 radio-name=
000C4288405F rate-selection=legacy rate-set=default scan-list=default
security-profile=default ssid=XxxxxX station-bridge-clone-mac=
6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps tdma-period-size=2
tx-power-mode=default update-stats-interval=disabled wds-cost-range=
50-150 wds-default-bridge=bridge1 wds-default-cost=100 wds-ignore-ssid=no
wds-mode=dynamic wireless-protocol=nv2 wmm-support=disabled
