help with a firewall address rule
Hello Friends, I want to know how to create a rule in the Firewall where I point to an address type * .domain.com instead of using an IP address, thanks :slight_smile:
The only time when firewall actually cares about anything else but IP addresses (and port numbers) is in L7 firewall. Which doesn’t work for HTTPS traffic because it’s encrypted.
If you describe use case, you might get better answer.
Easy peasy.
Just make a firewall address list entry and then in the firewall rule point to the list (in-interface-list) or (out-interface-list)
