hi
I need a script to limit a daily download bandwidth for specific users (150Mbytes)
my network : 192.168.1.0/24
REGARDS
hi
REGARDS
whats up guys… no one to help ![]()
I have done the following steps
I have limited bytes out in hotspot user properties (not the profile) (160Mb)
and in the schedular I ave scheduled a script to run daily
/ip hotspot user reset-counter
but nothing happens the counters didnt reset …
any ideas here
The reset-counter command needs to be passed the items to reset counters for. To reset all counters, use “/ip hotspot user reset-counters [/ip hotspot user find]”.
thanx for your reply
huh, maybe
/ip hotspot user reset-counters-all
Must be a new command, I don’t have that in 4.2
[admin@MikroTik] > /ip hotspot user reset-counters-all
bad command name reset-counters-all (line 1 column 18)
oops, sorry, I checked in /ip firewall filter, because I don’t have Hotspot installed %)
Finally its ok
I have tried this
manually and counters reseted
then using schedular
to work every 24 hours at 6 AM and its ok …
