Help with bandwidth control in mikrotik + external proxy
Hi, I was working on your guide I made all steps except one, I’ve downloaded de zph patch to squid3stable8 It comes with two patch one for squid source and one to the linux kernel but I see the linux kernel version do not match with my linux kernel version even browsing in the reposotories I dind’t find a match kernel my server is centos 5.2 x64 it’s running squid 3 stable 8 with zph patch.
What linux distro I must use?
I really need patch the kernel it’s mandatory?
If I use PPPoE or hotspot how to configure it, tried to patch squid and did it succesfully but after installing it I can not access internet something goes wrong, I says proxy refuzed connections. I am trying to set up squid on ubuntu 8.04. Do I need to patch kernel too in order to work? Does any one has squid patched and ripacked in .tar.gz if yes can any send the link?
Thank in advance!!!
I need help to set up my Mikrotik with squid. My configuration is:
Mikrotik Interfaces:
WAN 192.168.0.1
LAN 10.0.0.0/24 for PPPoE
SQUID 192.168.1.2
Squid: Lan 192.168.1.1
I need help how to use squid as transparent proxy what queues to create, what mangle rule te create.
I need help about this. From Mikrotik I can ping 192.168.1.1 but from my PPPoE clients I can not 192.168.1.1 but I can ping 192.168.1.2.
Did you use delay pools?
