help with bandwidth limit
RB750r2 @ 6.32.1
Ether1 = WAN = dsl router = dhcp ip assigned by isp
Ether2 = 10.0.0.1 = connected to 16 port switch = PC’s and Access Points are connected here
Ether3 =
Ether4 =
Ether5 =
How to properly setup bandwidth limiter ? I’ve used Simple queue and limited bandwidth per IP , it worked at first , but now it doesn’t , i don’t know why it stopped working , is there a simple way to limit all connections ?
check that firewall rule “fasttrack connection” is DISABLED
