Help with Basic VLAN
I’ve recently setup my router using the default settings and latest OS version, things are working well.
I’d now like to add a VLAN into the mix, the purpose of this VLAN is to create a separate network which will be utilised by Unifi Access Points
Current configuration
Eth1 = WAN
Eth2 = LAN (192.168.100.0/24) This goes into my main Unifi Switch where all devices are connected
Default Bridge
[admin@MikroTik] /interface bridge port> print
Flags: X - disabled, I - inactive, D - dynamic, H - hw-offload
 #     INTERFACE                                     BRIDGE                                     HW  PVID PRIORITY  PATH-COST INTERNAL-PATH-COST    HORIZON
 0   H ;;; defconf
       ether2-LAN                                    bridge                                     yes    1     0x80         10                 10       none
 1 I H ;;; defconf
       ether6-master                                 bridge                                     yes    1     0x80         10                 10       none
 2 I   ;;; defconf
       sfp1                                          bridge                                     no     1     0x80         10                 10       none
 3 I H ether3                                        bridge                                     yes    1     0x80         10                 10       none
 4 I H ether4                                        bridge                                     yes    1     0x80         10                 10       none
 5 I H ether5                                        bridge                                     yes    1     0x80         10                 10       none
 6 I H ether7                                        bridge                                     yes    1     0x80         10                 10       none
 7 I H ether8                                        bridge                                     yes    1     0x80         10                 10       none
 8 I H ether9                                        bridge                                     yes    1     0x80         10                 10       none
 9 I H ether10                                       bridge                                     yes    1     0x80         10                 10       none
I’d like to create a new VLAN, eg VLAN 10 and it have a network address of 10.0.10.0/24. What steps are required to implement this?
Appreciate any assistance.
  • Create a vlan sub-interface on the bridge with your relevant vlan number.
  • In “/switch vlan” create a vlan entry and add ether2 and switch1-cpu. You can also add other ports if they might handle vlan traffic. If it’s something like an RB2011 you may need to add switch2-cpu to the list to use ports 6+
  • Add an ip to the vlan interface and setup a dhcp server on it
just add a vlan to your bridge and add an ip to this new interface. next you need to tag the vlan at your ubnt device, and use it for your requirements.
see here
https://mum.mikrotik.com/presentations/ID13/khomeini.pdf
Thanks for the tips, will try these suggestions shortly.
Is it best to tag traffic for my current 192.168.100.0 network as well, or leave this untagged as-is?
I’ve made the suggested changes, does everything look ok? Any obvious mistakes?
When I try connect to the UniFi wireless network, it has VLAN 10 set, it fails trying to obtain IP address.
I think as a starting point I want to first take Unifi and the main switch connected on Eth2 out of the equation. If I can connect a PC to Eth3, and get an IP on the VLAN 10, that would be a good start. Is there anything additional I might need to achieve this?
Unifi Network
Thanks!
VLAN configuration depends on what kind of the device do you use. You can find more setup examples here:
https://wiki.mikrotik.com/wiki/Manual:CRS3xx_series_switches#Port_Based_VLAN
https://wiki.mikrotik.com/wiki/Manual:Interface/VLAN#Layer2_VLAN_examples
https://wiki.mikrotik.com/wiki/Manual:Switch_Chip_Features#VLAN_Example_1_.28Trunk_and_Access_Ports.29
I’m not sure why the majority of the suggestions are pre-6.41 since that hasn’t been the case for almost a year now. You’ve got most of it right but here is what needs to happen.
  1. Do not use the Switch setup. That’s wrong, it’s done via the Bridge now.
  2. Under Bridge go to the VLAN tab, you’ll want to add a new VLAN. Add the VLAN ID where it asks and then add the bridge itself and the ether ports (3 in this case) that need to be tagged.
  3. Enable VLAN Filtering on the Bridge.
Having the VLAN interface as a port on the bridge, correct.
Having the DHCP/IP Addresses assigned to the VLAN interface, correct.
You just need to set this up on the bridge instead of the switch interface.
Thanks Samot, this is what caused me confusion, lots of the content in forums, youtube etc is pre 6.41.
I’ve done as you suggested, removed the config in the “switch”
Enabled VLAN Filtering, and added the details in the VLAN tab.
However when I connect a PC into Eth3 I’m getting a 192.168.100.X IP address when it should be 10.0.10.X.
Cheers
Vlan10 must be on Bridge
In Bridge–>Ports, change ether3 PVID from 1 to 10
In Bridge–>Vlan make Bridge as tagged and ether3 untagged for Vlan id 10
Thanks CZFan,
Is this correct?
[admin@MikroTik] /interface bridge vlan> print
Flags: X - disabled, D - dynamic
 #   BRIDGE                      VLAN-IDS  CURRENT-TAGGED                      CURRENT-UNTAGGED
 0   bridge                      10
Done
 0   H ;;; defconf
 1 I H ;;; defconf
 2 I   ;;; defconf
 3 I H ether3                     bridge                  yes   10     0x80         10                 10       none
 **--snip--**
Like this?
Thank you.
/interface vlan
add interface=bridge1 name=vlan10 vlan-id=10
I already have this setup using a different name, will this be ok?
[admin@MikroTik] /interface vlan> print
Flags: X - disabled, R - running, S - slave
 #    NAME                   MTU ARP             VLAN-ID INTERFACE
 0 R  vlan10_Guest          1500 enabled              10 bridge
should be good to go, then if you want to prevent the guest vlan communication via layer 3 with other devices, use firewall filter rules
I’m very happy to be corrected, but for my own education, I hadn’t understood is as being as binary as using the switch menu before 6.41 and VLAN filtering after. My understanding was that if there was a VLAN switching requirement, you should still use the switch menu for devices with a switch chip, rather than VLAN filtering on the bridge, in order to maintain HW offload and wirespeed switching (with the exception of the crs3xx range that can maintain HW offload using VLAN filtering on the bridge).
If I’ve understood correctly, the answer given is right for the eth1 and eth2 question being asked by the OP as there is no switching going on. But wouldn’t there be benefit even after 6.41 to using the switch menu and chip to maintain HW offload if eth3, eth4 etc. were also used with VLAN’s?
@diddie17, you are 100% correct, if you want to switch VLAN’s, i.e. Ether3 and ether4 is in same vlan, then it is best to use switch vlan config except for crs3xx devices.
Between VLAN’s will happen with routing and this will go via cpu
Getting closer, when I connect to PC to Eth3 I now get an IP in the 10.0.10.0 subnet, however it can’t access the internet, or ping google dns 8.8.8.8.
Am I missing something? I’ve not put in any firewall rules to block traffic, the same rules remain as before I started trying to add this VLAN.
Traffic on the 192.168.100.0 subnet is fine, and has full connectivity.
Thanks again!
provide output of “export hide-sensitive”
# aug/04/2018 21:09:53 by RouterOS 6.42.6
# software id = UUZ2-Z8I4
# model = RouterBOARD 3011UiAS
# serial number =
add admin-mac=CC:2D:E0:7B:34:9F auto-mac=no comment=defconf name=bridge
set [ find default-name=ether1 ] name=ether1-WAN
set [ find default-name=ether2 ] name=ether2-LAN
set [ find default-name=ether6 ] name=ether6-master
/interface vlan
add interface=bridge name=vlan10_Guest vlan-id=10
add exclude=dynamic name=discover
add name=mactel
add name=mac-winbox
add name=WAN
add name=dhcp ranges=192.168.100.1-192.168.100.254
add name=Guest ranges=10.0.10.2-10.0.10.254
add address-pool=dhcp disabled=no interface=bridge name=LAN
add address-pool=Guest disabled=no interface=vlan10_Guest name=GUEST
add bridge=bridge comment=defconf interface=ether2-LAN
add bridge=bridge comment=defconf interface=ether6-master
add bridge=bridge comment=defconf hw=no interface=sfp1
add bridge=bridge interface=ether3 pvid=10
add bridge=bridge interface=ether4
add bridge=bridge interface=ether5
add bridge=bridge interface=ether7
add bridge=bridge interface=ether8
add bridge=bridge interface=ether9
add bridge=bridge interface=ether10
set discover-interface-list=discover
add bridge=bridge tagged=bridge untagged=ether3 vlan-ids=10
add interface=ether2-LAN list=discover
add interface=ether3 list=discover
add interface=ether4 list=discover
add interface=ether5 list=discover
add interface=sfp1 list=discover
add interface=ether6-master list=discover
add interface=ether7 list=discover
add interface=ether8 list=discover
add interface=ether9 list=discover
add interface=ether10 list=discover
add interface=bridge list=discover
add interface=bridge list=mactel
add interface=bridge list=mac-winbox
add interface=ether1-WAN list=WAN
add address=192.168.100.254/24 comment=defconf interface=ether2-LAN network=\
    192.168.100.0
add address=10.0.10.1 interface=vlan10_Guest network=10.0.10.0
/ip cloud
set ddns-enabled=yes
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid disabled=no interface=\
    ether1-WAN
add address=10.0.10.0/24 comment=GUEST dns-server=10.0.0.1 gateway=10.0.10.1 \
    netmask=24
add address=192.168.100.0/24 comment=LAN gateway=192.168.100.254 netmask=24
set allow-remote-requests=yes
/ip dns static
add address=192.168.100.254 name=router
/ip firewall address-list
add address=my.dynamic.host list=WANIP
add action=log chain=prerouting disabled=yes dst-port=22 log=yes log-prefix=\
    step1 protocol=tcp
add action=log chain=forward disabled=yes dst-port=22 log=yes log-prefix=\
    step2 protocol=tcp
add action=log chain=postrouting disabled=yes dst-port=22 log=yes log-prefix=\
    step3 protocol=tcp
add action=drop chain=input comment="Drop Ping from WAN" in-interface=\
    ether1-WAN protocol=icmp
add action=accept chain=input comment="defconf: accept ICMP" log-prefix=icmp \
    protocol=icmp
add action=accept chain=input comment="defconf: accept established,related" \
add action=accept chain=forward disabled=yes dst-port=8228 in-interface=\
    ether1-WAN log=yes log-prefix="accept forward port 22" protocol=tcp
add action=drop chain=input comment="defconf: drop all from WAN" \
    in-interface=ether1-WAN log-prefix="drop all from wan - input"
add action=accept chain=forward comment="defconf: accept established,related" \
    connection-state=invalid log-prefix="drop invalid"
    "defconf:  drop all from WAN not DSTNATed" connection-nat-state=!dstnat \
    connection-state=new in-interface=ether1-WAN log-prefix=\
    "drop from wan not dstnated"
add action=masquerade chain=srcnat comment="HAIRPIN Nat for loopback" \
    dst-address=192.168.100.0/24 src-address=192.168.100.0/24
    out-interface=ether1-WAN
add action=dst-nat chain=dstnat comment="SSH Server" dst-port=9922 \
    in-interface=ether1-WAN protocol=tcp to-addresses=192.168.100.150 \
    to-ports=22
/ip upnp
set enabled=yes
/ip upnp interfaces
add interface=bridge type=internal
/lcd
set backlight-timeout=never default-screen=stat-slideshow
/lcd interface
set ether3 disabled=yes
set ether4 disabled=yes
set ether5 disabled=yes
set sfp1 disabled=yes
set ether6-master disabled=yes
set ether7 disabled=yes
set ether8 disabled=yes
set ether9 disabled=yes
set ether10 disabled=yes
/lcd interface pages
set 0 interfaces=ether1-WAN,ether2-LAN
/system clock
set time-zone-name=Australia/Melbourne
/system ntp client
set enabled=yes primary-ntp=150.101.178.147 secondary-ntp=203.7.149.150
/system routerboard settings
set silent-boot=no
/system scheduler
/system script
/tool graphing interface
/tool graphing resource
add
/tool mac-server
set allowed-interface-list=mactel
/tool mac-server mac-winbox
set allowed-interface-list=mac-winbox
Below some corrections of mistakes and suggestions, so change these first and come back:
From
192.168.100.0
To
192.168.100.0
add address=10.0.10.1**/24** interface=vlan10_Guest network=10.0.10.0
From
netmask=24
To
add address=10.0.10.0/24 comment=GUEST dns-server=10.0.10.1**,8.8.8.8** gateway=10.0.10.1
netmask=24
add address=192.168.100.0/24 comment=LAN dns-server=192.168.100.254,8.8.8.8 gateway=192.168.100.254 netmask=24
From
To
set allow-remote-requests=yes servers=8.8.8.8,8.8.4.4
