Hello friends! I kindly need your help with bgp auto failover configuration. I will do this on production routers
So the set-up is as follow:
- An mpls cloud at the centre AS 11111
- MT router1 to the left AS 100 connecting to the cloud, /30 IP
- MT router2 to the right AS 100 connecting to the cloud, /30 IP
- A point-to-point link from router1 to router2, /30 IP
Now to you guys- help configure bgp fail-over such that link via AS 11111 are primary while the ptp link is secondary. I appreciate any further ideas.
My configuration did not work. The ptp link is taking over as primary when it should not! I’m guess some of you have resolved a similar problem.
Cheers
Sang
