iam quite familiar with capsman and wifi5 setup, iam using it for years at home.
But now i will try to help my friend with his home setup and iam stuck and confused that wifi6 capsman doesnt work the same way as wifi5.
Hardware is:
1xHaP ax3 as capsman server
3xHaP ax S as CAPs
I read a lot of guides and topics here, but i failed to set it up correctly.
I experienced a several issues:
1)when CAPs are managed by CAPSMAN, wifi interface wont turn on.
2)I try a few guides but i cant set up haP ax3 as capsman server for its own radios, the way with local loopback not working
3)is here any way to fast switching between CAPs?It work seamlessly at my home wifi5 setup, but it takes too long in wifi6 at my friends home.
4)How about frequencies in wifi6? Can capsman manage it all or should i set them up manualy and if so, how?
Do anyone have any reference config what works?
Actually i cant post my own config because i dont have hardware at my home, but it will come shortly and i need to setup it correctly because its 150km way to exchange them on my friends home.
Check my basic config. Client roaming works great. I am using 2x HAP AX3.
Config also works without problems with HAP AX S, I am tested it as a CAP this week.
Thank you for post your config, but iam really stuck with managing hap ax3 own radios. How i can check if evertyhing is OK? Actually iam out of time for testing, so can you post complete config? Thanks a lot..
I don’t think my full config will be interesting for you.
Check logs.
If everything right all interfaces will be up and if someone roams you will get messages like “40:5E:F6:4A:BF:94@wifi_AP1(SSID) roamed to 40:5E:F6:4A:BF:94@wifi_AP2(SSID), signal strength -64”
Mikrotik is not “out of box” solution, find your time for testing.
