jayden
January 5, 2012, 5:23pm
1
Greetings!!!
I am looking forward for your suggestions on the best radius server to use with Mikrotik 1100 series RB.
We are a small service provider with hotspots and optical fiber clients dealing with less than 100Mbps outbound connection in total.
Our requirements:
1.) Separate accounting for fiber and hotspots customers
2.) Prepaid PIN generation
3.) Bandwidth usage graphs
4.) Bandwidth usage limitations
5.) Customer portal where they can see usage graphs, download, upload stats
6.) User management with access levels
Your suggestion in this regard will be highly appreciated.
Thanks,
Jayden
dipdip
January 6, 2012, 10:40pm
2
hi jayden,
you can try radius manager from www.dmasoftlabs.com .
only thing it doesnt do is graphs otherwise its got a great interface
we have been installing it in quite a few large hotspots and WISP scenarios.
you can even get it on a trail basis.
I will also recommend to give a try to DMASOFTLAB RM.
Its really dirt cheap as compare to its rich features.
Check its Online Demo or get a trial version.
As dipdip said, it doesn’t do the graphing, but rest of features are awesome. I have install it at several operators with high level of satisfaction.
m4rk0
January 7, 2012, 10:58am
4
In our company We use DMA Radius Manager about 4 years.
Support is FAST, and its updated regularly…
