its a router for a docsis connection 11mbps down 2.2mbps up
2 interfaces, lan its a bridge interface, not using firewall on bridge
ethernet 5 its wan
its tuned for navigation traffic, voip, torrent, ipsec site to site vpns and ipsec ipip vpns, and management protocolos
192.168.0.0/16 its a summary of remote networks on vpns to mark it as VPN connections and leave it out of queues as well as ipip protocol, because its better to queue ipsec traffic itself to take in count encapsulation overhead.
its based on this:
http://www.mikrotik-routeros.com/2014/05/the-mother-of-all-qos-trees-v6-0/
but with some changes for example from ros 6.28 connection rate is not working
with this implementation i can use VOIP, navigation, and torrent (500 connections) all the time without problem or congestion
/queue type
add kind=red name=red_TEST_download red-avg-packet=1500 red-limit=40 \
red-max-threshold=40 red-min-threshold=20
add kind=red name=red_TEST_upload red-avg-packet=1500 red-burst=10 red-limit=\
20 red-max-threshold=20
/queue simple
add dst=ether5 max-limit=1800k/8250k name=queue1 queue=\
pcq-upload-default/pcq-download-default target=bridge1_lan total-queue=\
default
/queue tree
add max-limit=1800k name=TOTAL_U parent=global queue=default
add max-limit=8250k name=TOTAL_D parent=global queue=default
add limit-at=1M max-limit=1800k name=1_ACK_U packet-mark=ACK_U parent=TOTAL_U \
priority=1 queue=default
add limit-at=4M max-limit=8250k name=1_ACK_D packet-mark=ACK_D parent=TOTAL_D \
add limit-at=1M max-limit=1800k name=1_DNS_U packet-mark=DNS_U parent=TOTAL_U \
add limit-at=4M max-limit=8250k name=1_DNS_D packet-mark=DNS_D parent=TOTAL_D \
add limit-at=100k max-limit=1800k name=4_DUDE_U packet-mark=DUDE_U parent=\
TOTAL_U priority=4 queue=pcq-upload-default
add limit-at=250k max-limit=8250k name=4_DUDE_D packet-mark=DUDE_D parent=\
TOTAL_D priority=4 queue=pcq-download-default
add limit-at=1M max-limit=1800k name=1_ICMP_U packet-mark=ICMP_U parent=\
TOTAL_U priority=1 queue=default
add limit-at=4M max-limit=8250k name=1_ICMP_D packet-mark=ICMP_D parent=\
TOTAL_D priority=1 queue=default
add limit-at=100k max-limit=1800k name=5_HTTP_U packet-mark=HTTP_U parent=\
TOTAL_U priority=5 queue=pcq-upload-default
add limit-at=250k max-limit=8250k name=5_HTTP_D packet-mark=HTTP_D parent=\
TOTAL_D priority=5 queue=pcq-download-default
add limit-at=100k max-limit=1800k name=6_HTTP_U_BIG packet-mark=HTTP_BIG_U \
parent=TOTAL_U priority=6 queue=pcq-upload-default
add limit-at=250k max-limit=8250k name=6_HTTP_D_BIG packet-mark=HTTP_BIG_D \
parent=TOTAL_D priority=6 queue=pcq-download-default
add limit-at=100k max-limit=1800k name=5_OTHER_U packet-mark=OTHER_U parent=\
add limit-at=250k max-limit=8250k name=5_OTHER_D packet-mark=OTHER_D parent=\
add limit-at=4M max-limit=8250k name=4_IPSEC_D packet-mark=IPSEC_D parent=\
add limit-at=1M max-limit=1800k name=4_IPSEC_U packet-mark=IPSEC_U parent=\
add limit-at=4M max-limit=8250k name=2_VOIP_D packet-mark=VOIP_D parent=\
TOTAL_D priority=2 queue=default
add limit-at=1M max-limit=1800k name=2_VOIP_U packet-mark=VOIP_U parent=\
TOTAL_U priority=2 queue=default
add limit-at=250k max-limit=8250k name=6_MAIL_D packet-mark=MAIL_D parent=\
add limit-at=100k max-limit=1800k name=6_MAIL_U packet-mark=MAIL_U parent=\
add limit-at=100k max-limit=1800k name=7_OTHER_BIG_U packet-mark=OTHER_BIG_U \
parent=TOTAL_U priority=7 queue=red_TEST_upload
add limit-at=250k max-limit=8250k name=7_OTHER_D_BIG packet-mark=OTHER_BIG_D \
parent=TOTAL_D priority=7 queue=red_TEST_download
add limit-at=250k max-limit=8250k name=4_RDP_D packet-mark=RDP_D parent=\
add limit-at=100k max-limit=1800k name=4_RDP_U packet-mark=RDP_U parent=\
/ip firewall mangle
add action=set-priority chain=postrouting comment="dscp 46" dscp=46 \
new-priority=6
add action=set-priority chain=postrouting comment="dscp 48" dscp=48 \
new-priority=6
add action=mark-connection chain=postrouting comment=TUNELS dst-address=\
192.168.0.0/16 new-connection-mark=VPN out-interface=ether5 passthrough=\
no
add action=mark-connection chain=postrouting dst-address=192.168.0.0/16 \
new-connection-mark=VPN out-interface=ipip-tunnel-isescl58 passthrough=no
add action=mark-connection chain=forward dst-address=192.168.0.0/16 \
new-connection-mark=VPN out-interface=ether5 passthrough=no
add action=mark-connection chain=output dst-address=192.168.0.0/16 \
add action=mark-connection chain=postrouting new-connection-mark=VPN \
out-interface=ether5 passthrough=no protocol=ipencap
add action=mark-connection chain=forward new-connection-mark=VPN \
add action=mark-connection chain=output new-connection-mark=VPN \
add action=mark-connection chain=prerouting in-interface=ether5 \
new-connection-mark=VPN passthrough=no src-address=192.168.0.0/16
add action=mark-connection chain=prerouting in-interface=ipip-tunnel-isescl58 \
add action=mark-connection chain=forward in-interface=ether5 \
add action=mark-connection chain=forward in-interface=ipip-tunnel-isescl58 \
add action=mark-connection chain=input in-interface=ether5 \
add action=mark-connection chain=input in-interface=ipip-tunnel-isescl58 \
new-connection-mark=VPN passthrough=no protocol=ipencap
add action=mark-connection chain=output comment=DNS connection-mark=no-mark \
connection-state=new new-connection-mark=DNS out-interface=ether5 \
passthrough=no port=53 protocol=udp
add action=mark-connection chain=postrouting connection-mark=no-mark \
add action=mark-connection chain=input connection-state=new in-interface=\
ether5 new-connection-mark=DNS passthrough=no port=53 protocol=udp
add action=set-priority chain=postrouting connection-mark=DNS new-priority=6
add action=change-dscp chain=postrouting connection-mark=DNS new-dscp=48
add action=mark-packet chain=postrouting connection-mark=DNS new-packet-mark=\
DNS_U out-interface=ether5 passthrough=no
add action=mark-packet chain=prerouting connection-mark=DNS in-interface=\
ether5 new-packet-mark=DNS_D passthrough=no
add action=mark-connection chain=postrouting comment=ICMP connection-state=\
new new-connection-mark=ICMP passthrough=no protocol=icmp
add action=mark-connection chain=prerouting connection-state=new \
add action=change-dscp chain=postrouting connection-mark=ICMP new-dscp=48
add action=set-priority chain=postrouting connection-mark=ICMP new-priority=6
add action=change-dscp chain=output connection-mark=ICMP new-dscp=48
add action=set-priority chain=output connection-mark=ICMP new-priority=6
add action=mark-packet chain=postrouting connection-mark=ICMP \
new-packet-mark=ICMP_U out-interface=ether5 passthrough=no
add action=mark-packet chain=forward connection-mark=ICMP new-packet-mark=\
add action=mark-packet chain=output connection-mark=ICMP new-packet-mark=\
add action=mark-packet chain=prerouting connection-mark=ICMP in-interface=\
ether5 new-packet-mark=ICMP_D passthrough=no
add action=mark-packet chain=forward connection-mark=ICMP in-interface=ether5 \
add action=mark-packet chain=input connection-mark=ICMP in-interface=ether5 \
add action=change-dscp chain=postrouting comment=ACK new-dscp=48 packet-size=\
0-123 protocol=tcp tcp-flags=ack
add action=set-priority chain=postrouting new-priority=6 packet-size=0-123 \
add action=mark-packet chain=postrouting new-packet-mark=ACK_U out-interface=\
ether5 packet-size=0-123 passthrough=no protocol=tcp tcp-flags=ack
add action=mark-packet chain=forward new-packet-mark=ACK_U out-interface=\
add action=mark-packet chain=output new-packet-mark=ACK_U out-interface=\
add action=mark-packet chain=prerouting in-interface=ether5 new-packet-mark=\
ACK_D packet-size=0-123 passthrough=no protocol=tcp tcp-flags=ack
add action=mark-packet chain=forward in-interface=ether5 new-packet-mark=\
add action=mark-packet chain=input in-interface=ether5 new-packet-mark=ACK_D \
add action=mark-connection chain=prerouting comment=HTTP connection-mark=\
!HTTP_BIG connection-state=new dst-port=80,443,8080,554,8000,81,444,8409 \
new-connection-mark=HTTP protocol=tcp
add action=mark-connection chain=prerouting connection-mark=!HTTP_BIG \
new-connection-mark=HTTP protocol=udp
add action=mark-connection chain=prerouting connection-bytes=2000000-0 \
connection-mark=HTTP new-connection-mark=HTTP_BIG passthrough=no \
protocol=tcp
add action=mark-connection chain=postrouting connection-bytes=2000000-0 \
protocol=tcp
protocol=udp
protocol=udp
add action=mark-packet chain=postrouting connection-mark=HTTP_BIG \
new-packet-mark=HTTP_BIG_U out-interface=ether5 passthrough=no
add action=mark-packet chain=forward connection-mark=HTTP_BIG \
add action=mark-packet chain=output connection-mark=HTTP_BIG new-packet-mark=\
add action=mark-packet chain=prerouting connection-mark=HTTP_BIG \
in-interface=ether5 new-packet-mark=HTTP_BIG_D passthrough=no
add action=mark-packet chain=forward connection-mark=HTTP_BIG in-interface=\
add action=mark-packet chain=input connection-mark=HTTP_BIG in-interface=\
add action=mark-packet chain=postrouting connection-mark=HTTP \
new-packet-mark=HTTP_U out-interface=ether5 passthrough=no
add action=mark-packet chain=forward connection-mark=HTTP new-packet-mark=\
add action=mark-packet chain=output connection-mark=HTTP new-packet-mark=\
add action=mark-packet chain=prerouting connection-mark=HTTP in-interface=\
ether5 new-packet-mark=HTTP_D passthrough=no
add action=mark-packet chain=forward connection-mark=HTTP in-interface=ether5 \
add action=mark-packet chain=input connection-mark=HTTP in-interface=ether5 \
add action=mark-connection chain=prerouting comment=DUDE connection-state=new \
dst-port=2210,8291,10008,22,23,222 new-connection-mark=DUDE passthrough=\
no protocol=tcp
add action=mark-packet chain=postrouting connection-mark=DUDE \
new-packet-mark=DUDE_U out-interface=ether5 passthrough=no
add action=mark-packet chain=forward connection-mark=DUDE new-packet-mark=\
add action=mark-packet chain=output connection-mark=DUDE new-packet-mark=\
add action=mark-packet chain=prerouting connection-mark=DUDE in-interface=\
ether5 new-packet-mark=DUDE_D passthrough=no
add action=mark-packet chain=forward connection-mark=DUDE in-interface=ether5 \
add action=mark-packet chain=input connection-mark=DUDE in-interface=ether5 \
add action=mark-connection chain=prerouting comment=RDP connection-state=new \
dst-port=3389 new-connection-mark=RDP passthrough=no protocol=tcp
add action=mark-packet chain=postrouting connection-mark=RDP new-packet-mark=\
RDP_U out-interface=ether5 passthrough=no
add action=mark-packet chain=forward connection-mark=RDP new-packet-mark=\
add action=mark-packet chain=output connection-mark=RDP new-packet-mark=RDP_U \
add action=mark-packet chain=prerouting connection-mark=RDP in-interface=\
ether5 new-packet-mark=RDP_D passthrough=no
add action=mark-packet chain=forward connection-mark=RDP in-interface=ether5 \
add action=mark-packet chain=input connection-mark=RDP in-interface=ether5 \
add action=mark-connection chain=prerouting comment=MAIL connection-state=new \
dst-port=25,110,143,465,585,993,995 new-connection-mark=MAIL passthrough=\
no protocol=tcp
add action=mark-packet chain=postrouting connection-mark=MAIL \
new-packet-mark=MAIL_U out-interface=ether5 passthrough=no
add action=mark-packet chain=forward connection-mark=MAIL new-packet-mark=\
add action=mark-packet chain=output connection-mark=MAIL new-packet-mark=\
add action=mark-packet chain=prerouting connection-mark=MAIL in-interface=\
ether5 new-packet-mark=MAIL_D passthrough=no
add action=mark-packet chain=forward connection-mark=MAIL in-interface=ether5 \
add action=mark-packet chain=input connection-mark=MAIL in-interface=ether5 \
add action=mark-connection chain=prerouting comment=IPSEC connection-state=\
new new-connection-mark=IPSEC passthrough=no protocol=ipsec-esp
add action=mark-connection chain=postrouting connection-state=new \
add action=mark-connection chain=forward connection-state=new \
add action=mark-connection chain=input connection-state=new \
add action=mark-connection chain=output connection-state=new \
add action=mark-connection chain=prerouting connection-state=new dst-port=\
500,4500 new-connection-mark=IPSEC passthrough=no protocol=udp
add action=mark-connection chain=postrouting connection-state=new dst-port=\
add action=mark-connection chain=forward connection-state=new dst-port=\
add action=mark-connection chain=input connection-state=new dst-port=500,4500 \
add action=mark-connection chain=output connection-state=new dst-port=\
add action=mark-packet chain=postrouting connection-mark=IPSEC \
new-packet-mark=IPSEC_U out-interface=ether5 passthrough=no
add action=mark-packet chain=forward connection-mark=IPSEC new-packet-mark=\
add action=mark-packet chain=output connection-mark=IPSEC new-packet-mark=\
add action=mark-packet chain=prerouting connection-mark=IPSEC in-interface=\
ether5 new-packet-mark=IPSEC_D passthrough=no
add action=mark-packet chain=forward connection-mark=IPSEC in-interface=\
add action=mark-packet chain=input connection-mark=IPSEC in-interface=ether5 \
add action=mark-connection chain=prerouting comment=VOIP connection-mark=\
no-mark connection-rate=0-25k new-connection-mark=VOIP passthrough=no \
protocol=udp
add action=mark-packet chain=postrouting connection-mark=VOIP \
new-packet-mark=VOIP_U out-interface=ether5 packet-size=0-260
add action=mark-packet chain=forward connection-mark=VOIP new-packet-mark=\
VOIP_U out-interface=ether5 packet-size=0-260 passthrough=no
add action=mark-packet chain=output connection-mark=VOIP new-packet-mark=\
add action=change-dscp chain=postrouting new-dscp=48 packet-mark=VOIP_U
add action=set-priority chain=postrouting new-priority=6 packet-mark=VOIP_U \
passthrough=no
add action=mark-packet chain=prerouting connection-mark=VOIP in-interface=\
ether5 new-packet-mark=VOIP_D packet-size=0-260 passthrough=no
add action=mark-packet chain=forward connection-mark=VOIP in-interface=ether5 \
add action=mark-packet chain=input connection-mark=VOIP in-interface=ether5 \
add action=change-dscp chain=postrouting new-dscp=48 packet-mark=VOIP_D
add action=set-priority chain=postrouting new-priority=6 packet-mark=VOIP_D \
passthrough=no
add action=mark-packet chain=postrouting comment="NO VOIP" connection-mark=\
VOIP new-packet-mark=OTHER_BIG_U out-interface=ether5 passthrough=no
ether5 new-packet-mark=OTHER_BIG_D passthrough=no
add action=mark-connection chain=prerouting comment="OTHER TCP" \
connection-mark=!OTHER_BIG connection-state=new dst-port=\
!80,443,8080,554,8000,81,444,8409,10008 new-connection-mark=OTHER \
protocol=tcp
add action=mark-connection chain=prerouting connection-bytes=1000000-0 \
connection-mark=OTHER dst-port=!80,443,8080,554,8000,81,444,8409,10008 \
new-connection-mark=OTHER_BIG passthrough=no protocol=tcp
add action=mark-packet chain=postrouting connection-mark=OTHER \
new-packet-mark=OTHER_U out-interface=ether5 passthrough=no
add action=mark-packet chain=forward connection-mark=OTHER new-packet-mark=\
add action=mark-packet chain=output connection-mark=OTHER new-packet-mark=\
add action=mark-packet chain=prerouting connection-mark=OTHER in-interface=\
ether5 new-packet-mark=OTHER_D passthrough=no
add action=mark-packet chain=forward connection-mark=OTHER in-interface=\
add action=mark-packet chain=input connection-mark=OTHER in-interface=ether5 \
add action=mark-packet chain=postrouting connection-mark=OTHER_BIG \
add action=mark-packet chain=forward connection-mark=OTHER_BIG \
add action=mark-packet chain=output connection-mark=OTHER_BIG \
add action=mark-packet chain=prerouting connection-mark=OTHER_BIG \
in-interface=ether5 new-packet-mark=OTHER_BIG_D passthrough=no
add action=mark-packet chain=forward connection-mark=OTHER_BIG in-interface=\
add action=mark-packet chain=input connection-mark=OTHER_BIG in-interface=\
add action=mark-packet chain=postrouting new-packet-mark=OTHER_BIG_U \
out-interface=ether5 packet-mark=no-mark passthrough=no
add action=mark-packet chain=forward new-packet-mark=OTHER_BIG_U \
add action=mark-packet chain=output new-packet-mark=OTHER_BIG_U \
OTHER_BIG_D packet-mark=no-mark passthrough=no
add action=mark-packet chain=input in-interface=ether5 new-packet-mark=\
add chain=postrouting disabled=yes
