i need help with some configuration, I have strange problem with mine. Please tell me what is wrong
below is my setup, but strangely the network is very very slow, e.g. when loading webpages, it time out the first time, many sites fail to connect and so on and when i remove all my config everything is fine again.
here is my config
# 2024-02-29 23:02:16 by RouterOS 7.13.5
# software id = U3ZI-3UB1
# model = RB750Gr3
# serial number = CC220EBE14C3
add igmp-snooping=yes ingress-filtering=no name=bridge1 port-cost-mode=short \
vlan-filtering=yes
/interface vlan
add interface=bridge1 name=Guest_VLAN vlan-id=30
add interface=bridge1 name=Mgmt_VLAN vlan-id=99
add interface=bridge1 name=Office_VLAN vlan-id=10
add interface=bridge1 name=Training_VLAN vlan-id=20
add name=WAN
add name=Internal
add name=Guest
add name=Mgmt
add name=Training
/ip hotspot profile
add name=Office_POOL ranges=192.168.2.121-192.168.2.250
add name=Training_POOL ranges=192.168.1.151-192.168.1.254
add name=Guest_POOL ranges=10.0.30.30-10.0.30.250
add name=Mgmt_POOL ranges=192.168.99.5-192.168.99.254
add address-pool=Office_POOL interface=Office_VLAN lease-time=10m name=\
Office_DHCP
add address-pool=Training_POOL interface=Training_VLAN lease-time=10m name=\
Training_DHCP
add address-pool=Guest_POOL interface=Guest_VLAN lease-time=10m name=\
Guest_DHCP
add address-pool=Mgmt_POOL interface=Mgmt_VLAN lease-time=10m name=Mgmt_DHCP
/port
set 0 name=serial0
add bridge=bridge1 ingress-filtering=no interface=ether2 internal-path-cost=\
10 path-cost=10 pvid=10
add bridge=bridge1 frame-types=admit-only-untagged-and-priority-tagged \
interface=ether3 internal-path-cost=10 path-cost=10 pvid=10
interface=ether4 internal-path-cost=10 path-cost=10 pvid=99
add bridge=bridge1 frame-types=admit-only-vlan-tagged interface=ether5 \
/interface bridge vlan
add bridge=bridge1 tagged=bridge1,ether5 untagged=ether3 vlan-ids=10
add bridge=bridge1 tagged=bridge1,ether5 vlan-ids=20
add bridge=bridge1 tagged=bridge1,ether5 vlan-ids=30
add bridge=bridge1 tagged=bridge1,ether5 untagged=ether4 vlan-ids=99
/interface detect-internet
set wan-interface-list=WAN
add interface=ether1 list=WAN
add interface=Office_VLAN list=Internal
add interface=Guest_VLAN list=Guest
add interface=Mgmt_VLAN list=Mgmt
add interface=Training_VLAN list=Training
add interface=Mgmt_VLAN list=Internal
add address=192.168.99.1/24 interface=Mgmt_VLAN network=192.168.99.0
add address=192.168.2.1/24 interface=Office_VLAN network=192.168.2.0
add address=192.168.1.1/24 interface=Training_VLAN network=192.168.1.0
add address=10.0.30.1/24 interface=Guest_VLAN network=10.0.30.0
/ip cloud
set update-time=no
/ip dhcp-client
add address=10.0.30.0/24 dns-server=10.0.30.1 gateway=10.0.30.1
add address=192.168.1.0/24 dns-server=192.168.1.1 gateway=192.168.1.1
add address=192.168.2.0/24 dns-server=192.168.2.1 gateway=192.168.2.1
add address=192.168.3.0/24 dns-server=192.168.3.1 gateway=192.168.3.1
add address=192.168.99.0/24 dns-server=192.168.99.1 gateway=192.168.99.1
set allow-remote-requests=yes servers=1.1.1.1,1.0.0.1
"ATikconf: accept established,related,untracked" connection-state=\
add action=drop chain=input comment="ATikconf: drop invalid" \
connection-state=invalid
add action=accept chain=input comment="ATikconf: accept ICMP" protocol=icmp
add action=accept chain=input comment="Allow Internal" in-interface-list=\
Internal
add action=accept chain=input comment="Allow Training" in-interface-list=\
Training
add action=accept chain=input comment="Allow Guest" in-interface-list=Guest
add action=accept chain=input comment="Allow Mgmt_Vlan Full Access" \
in-interface-list=Mgmt
add action=fasttrack-connection chain=forward comment="ATikconf: fasttrack" \
"ATikconf: accept established,related, untracked" connection-state=\
add action=accept chain=forward comment="Training_VLAN to Office_VLAN" \
connection-state=new in-interface-list=Training out-interface-list=\
Internal
add action=accept chain=forward comment="Office_VLAN to Training_VLAN" \
connection-state=new in-interface-list=Internal out-interface-list=\
Training
add action=accept chain=forward comment="Internal Internet Access only" \
connection-state=new in-interface-list=Internal out-interface-list=WAN
add action=accept chain=forward comment="Guest Internet Access only" \
connection-state=new in-interface-list=Guest out-interface-list=WAN
add action=accept chain=forward comment="mgmt to mgmt" in-interface-list=Mgmt \
out-interface-list=Mgmt
add action=drop chain=forward comment="ATikconf: drop invalid" \
"ATikconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat \
add action=masquerade chain=srcnat comment="Default masquerade" \
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh address=192.168.99.0/24
set api disabled=yes
set winbox address=192.168.99.0/24
set api-ssl disabled=yes
/ip socks
set auth-method=password enabled=yes port=20907 version=5
/ip socks users
add name=es9999
/ip ssh
set strong-crypto=yes
/system clock
set time-zone-name=Asia/Singapore
/system identity
set name=Router
/system logging
set 1 action=disk
/system note
set show-at-login=no
/system ntp client
set enabled=yes
/system ntp server
set broadcast=yes broadcast-addresses=192.168.99.1 enabled=yes
/system ntp client servers
add address=sg.pool.ntp.org
/tool bandwidth-server
set enabled=no
/tool mac-server
/tool mac-server mac-winbox
/tool mac-server ping
set enabled=no
VLAN 10 is supposed to have internet, and access into VLAN 20
VLAN 20 is supposed to access a server VLAN 10 but no internet
VLAN 30 is just internet no access to VLAN 10 & 20
Your firewall rules are where the most work is needed, its clear you got mixed up or at least didnt think through the logic.
For example you have the office vlan accessing the training vlan and then you have the training vlan accessing the office vlan.
But you dont use vlan subnets you actually use interface lists which included other vlans
a. not targeted, by using internal for example you give training access to office AND Mgmt.… .
b. nonsensical, if you wish a to originate traffic to access b, and then you wish b to originate traffic to access a,
THEN THERE IS LITTLE POINT IN HAVING TWO SEPARATE VLANs.
what might make sense, is that you want to give the office access to training, and thats it.
