help with configure Briged lan - to wan
good day, I want to ask for your advice. I can’t connect the internet to the mikrotik ax2 router. I can ping 8.8.8.8 from the router, but I can’t get to the wan either from the wifi or from the cable. THX guys
Here is my config>
2024-07-02 13:43:25 by RouterOS 7.15.2
# software id = 3MIE-1QDH
# model = C52iG-5HaxD2HaxD
# serial number = XXXXXXXXXXX
add name=bridge2
set [ find default-name=ether1 ] poe-out=off rx-flow-control=auto \
    tx-flow-control=auto
add name=WAN
add name=LAN
/interface wifi datapath
add bridge=bridge2 bridge-cost=1 disabled=no interface-list=WAN name=datapath1
/interface wifi
set [ find default-name=wifi1 ] configuration.country=Slovakia .mode=ap .ssid=\
    "Bacigala 5" datapath=datapath1 datapath.bridge=bridge2 .bridge-cost=1 \
    .interface-list=all disabled=no
set [ find default-name=wifi2 ] configuration.country=Slovakia .mode=ap .ssid=\
    "Bacigala 2" datapath=datapath1 datapath.bridge=bridge2 .interface-list=all \
    .vlan-id=none disabled=no
add name=dhcp ranges=192.168.3.2-192.168.3.254
add name=dhcp_pool1 ranges=192.168.3.2-192.168.3.254
add address-pool=dhcp disabled=yes interface=ether1 name=dhcp1 relay=\
    192.168.3.1
add address-pool=dhcp_pool1 delay-threshold=30m interface=bridge2 name=server1 \
    server-address=192.168.3.1
add bridge=bridge2 interface=ether2
add bridge=bridge2 interface=ether3
add bridge=bridge2 interface=ether4
add bridge=bridge2 interface=ether5
add bridge=bridge2 interface=wifi1
add bridge=bridge2 interface=wifi2
add interface=ether1 list=WAN
add disabled=yes interface=wifi1 list=LAN
add interface=bridge2 list=LAN
add disabled=yes interface=wifi2 list=LAN
add address=192.168.3.1/24 interface=bridge2 network=192.168.3.0
/ip dhcp-client
add address=192.168.3.0/24 gateway=192.168.3.1
/ip upnp
set enabled=yes
/ip upnp interfaces
add interface=bridge2 type=internal
add interface=ether1 type=external
/system clock
set time-zone-name=Europe/Bratislava
/system note
set show-at-login=no
Hi, if you didn’t remove any part of the export, then the whole firewall is missing (including the NAT masquerade/src-nat rules to allow you to navigate to Internet) and whole IPv6 config as well.
I would recommend to do a full config reset and start all over again (default settings include IPv4 NAT al least for that router).
