yes, if you want to use two routers as routers you need change one of them network to 192.168.X.0/24 where X is any number from 0-255 except 88. also you can make one network using two mikrotiks - second mikrotik must be changed to bridge mode.
Thank you. I forgot to mention that the mikrotik routers are about 1000 miles away from one anohter one is at my house, other is in the country i work in. thanks!
