Help with cpe
I have some cpe’s that won’t talk with the MIKROTIK ROUTER OS via pppoe.
Help
Hmmmm :wink: Do you have “some” more information - you won’t get much help with just this post…
Yes I do, however when I ask the question in its full form, the admin deleted the question, and said it had nothing to do with mikrotik router os.
Perhaps you can outline your problem?
I have been using brand X cpe; it will pass a pppoe request to the mikrotik os from a laptop requesting a pppoe session, but will not pass the request from a linksys or d-link (cheap customer priced router).
Now brand x cpe is a high power radio 200mW to 250mW
Is there any other cpe high power radio that anyone can suggest that will pass the pppoe request from linksys and dlink routers.
