BobCat
February 27, 2025, 2:34pm
1
Good day.
I been trying to setup IKEv2 connection the past few weeks and was able to get this far.
Now im at the point where the logs shows “DH group number mismatch: 21 != 14” error.
The IT of the company i need to connect to sais i must use dh group21.
Dh group 21 means ecp521?
So why does it not working?
My config look like this.
/ip ipsec profile
add dh-group=ecp521 enc-algorithm=aes-256 hash-algorithm=sha512 lifetime=8h name="IKE2 VPN" nat-traversal=yes prf-algorithm=sha512
/ip ipsec peer
add address=(some ip) exchange-mode=ike2 name="IKE2 VPN" profile="IKE2 VPN"
/ip ipsec proposal
add disabled=yes enc-algorithms=aes-256-cbc name="IKE2 VPN" pfs-group=none
add auth-algorithms=sha512 enc-algorithms=aes-256-cbc lifetime=8h name="IKE2 VPN" pfs-group=ecp521
/ip ipsec identity
add generate-policy=port-strict mode-config="IKE2 VPN" peer="IKE2 VPN" policy-template-group="IKE2 VPN" secret=password
/ip ipsec policy
add comment=temp dst-address=192.168.0.0/24 peer="IKE2 VPN" proposal="IKE2 VPN" src-address=10.55.1.116/29 tunnel=yes
add dst-address=10.10.10.0/24 peer="IKE2 VPN" proposal="IKE2 VPN" src-address=10.55.1.116/29 tunnel=yes
add disabled=yes dst-address=10.11.0.0/16 peer="IKE2 VPN" proposal="IKE2 VPN" src-address=10.55.1.116/29 tunnel=yes
BobCat
February 28, 2025, 8:16am
2
So i created pcap file and imported it into wireshark.
Under Payload: Key Exchange it shows DH Group #: 2048 bit MODP group (14)
Does this means the remote site is using DH group 14 and my site is using DH group 21?
Try to check both DH groups and you will know
BobCat
February 28, 2025, 9:50am
4
Ok i wil lask them to check.
If i change the DH Group to ecp384 on my side then the error will change to DH group number mismatch: 20 != 14.
If i choose any other DH Group except ecp521 or ecp384 i will get error “can’t agree on IKE proposal, my config:”
THe remote site is using cisco.
What I meant was to check several DH Group. The counter-part wants some DH-Group, and you can check several of them. They will agree in one DH-Group in common.
So, if you check ALL DH Group, the peers should agree and you will see which DH-Group is the one the counter-part wants.
/ip ipsec profile
add dh-group=dh-group="x25519,ecp256,ecp384,ecp521,modp8192,modp6144,modp4096,modp3072,modp2048,modp1536,modp1024,modp768" enc-algorithm=aes-256 hash-algorithm=sha512 lifetime=8h name="IKE2 VPN" nat-traversal=yes prf-algorithm=sha512
BobCat
February 28, 2025, 10:18am
6
If i select all dh groups then mikrotik log will show DH group number mismatch: 20 != 14
/ip ipsec profile
add dh-group=ecp256,ecp384,ecp521,ec2n185,ec2n155,modp8192,modp6144,modp4096,modp3072,modp2048,modp1536,modp1024,modp768 enc-algorithm=aes-256 hash-algorithm=sha512 lifetime=8h name=\
"IKE2 VPN
" prf-algorithm=sha512
12:15:46 ipsec processing payload: NONCE
12:15:46 ipsec processing payload: SA
12:15:46 ipsec IKE Protocol: IKE
12:15:46 ipsec proposal #1
12:15:46 ipsec enc: aes256-cbc
12:15:46 ipsec prf: hmac-sha256
12:15:46 ipsec auth: sha256
12:15:46 ipsec dh: modp2048
12:15:46 ipsec proposal #2
12:15:46 ipsec dh: modp1536
12:15:46 ipsec proposal #3
12:15:46 ipsec proposal #4
12:15:46 ipsec proposal #5
12:15:46 ipsec proposal #6
12:15:46 ipsec proposal #7
12:15:46 ipsec prf: hmac-sha512
12:15:46 ipsec auth: sha512
12:15:46 ipsec dh: ecp384
12:15:46 ipsec proposal #8
12:15:46 ipsec dh: ecp521
12:15:46 ipsec proposal #9
12:15:46 ipsec prf: hmac-sha1
12:15:46 ipsec auth: sha1
12:15:46 ipsec proposal #10
12:15:46 ipsec enc: aes256-gcm
12:15:46 ipsec enc: aes192-gcm
12:15:46 ipsec enc: aes128-gcm
12:15:46 ipsec prf: hmac-sha384
12:15:46 ipsec dh: ecp256
12:15:46 ipsec dh: modp4096
12:15:46 ipsec dh: modp3072
12:15:46 ipsec matched proposal:
12:15:46 ipsec processing payload: KE
12:15:46 ipsec DH group number mismatch: 20 != 14
12:15:46 ipsec adding notify: INVALID_KE_PAYLOAD
12:15:46 ipsec,debug => (size 0xa)
I wonder if i should try to update ROS version to lastest?
Running 6.49.13 longterm at the moment
Or if remote router has wrong settings.
They claim it is group 21 but why im getting group 14.
Ok, I think the problem is in PROPOSAL and not in Profile.
You have:
/ip ipsec proposal
add auth-algorithms=sha512 enc-algorithms=aes-256-cbc lifetime=8h name="IKE2 VPN" ***pfs-group=ecp521***
This means PFS Group 21, but maybe they want this to be PFS Group 14:
/ip ipsec proposal
add auth-algorithms=sha512 enc-algorithms=aes-256-cbc lifetime=8h name="IKE2 VPN" ***pfs-group=modp2048***
BobCat
February 28, 2025, 4:11pm
8
Hello JPrietove.
Unfortunately that did not solve the issue.
add auth-algorithms=sha512 enc-algorithms=aes-256-cbc lifetime=8h name=“IKE2 VPN” pfs-group=modp2048
Might this be the reason why it is not working…
Ether1 is connected to fiber router (ether1 172.25.170.1) and gateway of fiber router is 172.25.170.2
In the mikrotik log is show packets is being sent from 172.25.170.1 to (some ip of the remote ikev2 router)
I have tested the current settings between two mikrotiks and it does work.
The other mikrotik shows connection comes from the public ip assigned to the 172.25.170.1 mikrotik which is 41.65.X.X
The IT’s at the cisco router side suggested that i remove the fiber router and create PPPOE-OUT interface on router.
Then the packets will show its coming from the public ip instead of the wan port ip paddress.
Could you please post a network diagram, with IP addresses? Is your MikroTik behind NAT?
BobCat
February 28, 2025, 7:42pm
10
Network diagram
Mikrotik1 Fiber router
(ethet10 = 172.25.170.1) -----> 172.25.170.2
add comment="default route" distance=1 gateway=172.25.170.2
and
add address=192.168.0.1/24 interface=ether1 network=192.168.0.0
add address=172.25.170.1/24 interface=ether10 network=172.25.170.0
Yes router is currently behind nat.
===== sending 38 bytes from 172.25.170.1[500] to some_ip 500]
BobCat
March 4, 2025, 11:26am
11
Hello jprietove
Im glad to report that the tunnel is finally up and running.
Looks like it was setting on their side.
Thank you so much for trying to help me.
