Hi, I am new with this… I tried the Dude and it is a great tool… I discover my network and all it is pretty cool, now I notice that some of my servers had counters like CPU usage and Memory, so I try to enable the same for all the servers and I am not able, I read the manual and this forum but I have no idea, I believe I have to add manually the OIDs to the dude for specific hardware to work with the SNMP, but how do I find the OIDs for any hardware??.. can someone provide me with the steps necessary to add the proper monitors on my servers please!!! I really like this tool and I want to learn how to use it properly!! thank you for any replies
Please anyone… I just want to understand how it works… PLEASE someone ![]()
Is SNMP enabled on your servers? And configured? Probably not… First look into that.
Actually I did installed on the servers but they did not show, I want to understand how to add the counters, I found on the internet that the hardware should be capable
any help??
thanks
Installed, ok. But also configured properly? Security setup correctly? Community strings? Etc.?
I defenetly did not do that…!!! can you recomend any website that I could read about Community strings, Security setup and so on… I really apreciate your help… thank you..!!!
