help with dynamic wpa
Hi all,
I have been trying to make this work can anybody help:
In a database connected to Radius there is an entry with mac address and wpa key for each user. Ideally I want each user to have their own different wpa key from this database. Problem is it wont authenticate with the key in the database. I can’t see in the docs a radius attribute for wpa key only wep key. I don’t want to use EAP etc just to have a unique wpa key.
I have this working fine with a wep key using radius attribute Mikrotik-Wireless-Enc-Algo := 2 but would like to use WPA Can anybody advise?
anybody please ??
This is only possible in RouterOS v3.0.
Ok that explains why docs did not cover a radius attribute for WPA.
Thanks for clearing that up Uldis.
Hi Uldis.
Where can i find info on the new attributes that is supported in v3.
Would also like to do wpa key from radius.
