Help with general configuration and scripts
I have MikroTik router RB433. I can’t connect to it with WinBox, I don’t know why.
After I connect with it I’ll need to save the current configuration, then start writing scripts.
In the future, I must connect to the router with SSH.
The router will not be used as a network device but as the source of the electromagnetic fields in the laboratory.
The most important script will change the transmitted power.
I think I can write some of the scripts on my own but I’ll need help for example with the one I just mentioned.
The 1st thing is to connect with the router.
I don’t have any experience with MikroTik routers so I need someone to guide me, preferably through screen sharing and talking for example on Discord but I’ll take ANY help.
The 1st issue to figure out is how to connect with the router.
I offer $$ for the help.
If you don`t have access to the Device,
Reset the RB433 via the Reset-Button
It isn`t hard to do, look in the Manual for instruction for more Info
(https://i.mt.lv/cdn/product_files/rb433GL-qg_181013.pdf)
Hi;
First of all, the device you are using is an old device. Get an old version of Winbox to be able to connect. Then if you send the configuration details to the e-mail, I will try to help. Before starting the process, take care to reset the device and have your cable connection on ether2.
