hi all - I’ve been pretty happy with my hap ac2 but i’ve got one issue I’m struggling with. I can connect via L2TP VPN from my laptop when I am traveling but I only can access resources on the LAN. I’d like to have internet access through the VPN, just like I was connected locally. Confusingly, it works properly when I activate the VPN connection while I am on the WLAN. I must be missing a firewall rule for the l2tp subnet (192.168.70.0/24) but I can’t figure it out. A diagram of my LAN topology is attached and here is an export of my config. What am I missing? Thanks!
# nov/19/2019 14:50:38 by RouterOS 6.45.7
# software id = W6AM-FM09
# model = RBD52G-5HacD2HnD
# serial number = B4A30861xxxx
add admin-mac=CC:2D:E0:91:xx:xx auto-mac=no comment=defconf name=bridge
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX \
disabled=no distance=indoors frequency=auto mode=ap-bridge ssid=wifi2 \
wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-n/ac channel-width=20/40/80mhz-XXXX \
disabled=no distance=indoors frequency=auto mode=ap-bridge ssid=wifi5 \
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa2-psk mode=dynamic-keys \
supplicant-identity=MikroTik wpa-pre-shared-key=sharedkey \
wpa2-pre-shared-key=sharedkey
/ip hotspot profile
/ip ipsec peer
add name=l2tpserver passive=yes
/ip ipsec profile
set [ find default=yes ] enc-algorithm=aes-256
/ip ipsec proposal
set [ find default=yes ] enc-algorithms=aes-256-cbc,aes-256-ctr,aes-256-gcm
add name=dhcp ranges=192.168.88.10-192.168.88.254
add name=ike2-pool ranges=192.168.0.77
add address-pool=dhcp disabled=no interface=bridge name=defconf
/ppp profile
add dns-server=192.168.88.1 local-address=192.168.60.1 name=ipsec_vpn
add bridge=bridge comment=defconf interface=wlan2
/interface l2tp-server server
set authentication=mschap1,mschap2 default-profile=ipsec_vpn enabled=yes
add address=192.168.88.1/24 comment=defconf interface=ether2 network=\
192.168.88.0
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid disabled=no interface=\
ether1
/ip dhcp-server lease
add address=192.168.88.23 mac-address=6C:40:08:B1:20:C4 server=defconf
add address=192.168.88.0/25 comment=defconf gateway=192.168.88.1
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 name=router.lan
add action=accept chain=input port=1701,500,4500 protocol=udp
add action=accept chain=input protocol=ipsec-esp
established,related,untracked
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
add action=accept chain=input src-address=192.168.60.0/24
add action=fasttrack-connection chain=forward comment=\
"defconf: fasttrack established,related" connection-state=\
established,related
connection-state=invalid
"defconf: accept established, related,untracked" connection-state=\
/ip firewall mangle
add action=mark-connection chain=forward comment=\
"mark ipsec connections to exclude them from fasttrack" ipsec-policy=\
out,ipsec new-connection-mark=ipsec
in,ipsec new-connection-mark=ipsec
/ip ipsec identity
add generate-policy=port-override peer=l2tpserver secret=sharedsecret
/ip ipsec policy
set 0 dst-address=0.0.0.0/0 src-address=0.0.0.0/0
add distance=1 dst-address=192.168.60.0/24 gateway=bridge pref-src=\
192.168.88.1 scope=10
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh port=2200
set www-ssl certificate=webfig disabled=no
set api disabled=yes
set api-ssl disabled=yes
/ppp secret
add name=admin password="password" profile=\
ipsec_vpn remote-address=192.168.60.2 service=l2tp
/system clock
set time-zone-name=America/Denver
/system identity
set name=hotbox
/system scheduler
add interval=1m name=dynu-ddns on-event="/system script run dynu-ddns\\r\\n" \
policy=read,write,test start-time=startup
/system script
add dont-require-permissions=no name=dynu-ddns owner=admin policy=\
ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source="#\
\_get the current IP address from the internet\
\n/tool fetch mode=http address=\"checkip.dynu.com\" src-path=\"/\" dst-pa\
th=\"/dynu.checkip.html\"\
\n:local result [/file get dynu.checkip.html contents]\
\n\
\n# parse the current IP result\
\n:local resultLen [:len \$result]\
\n:local startLoc [:find \$result \": \" -1]\
\n:set startLoc (\$startLoc + 2)\
\n:local currentIP [:pick \$result \$startLoc \$resultLen]\
\n:global ddnsuser mydynu\
\n:global ddnspass dynupasswd\
\n:global ddnshost mydynu.dynu.net\
\n:global ipddns [:resolve \$ddnshost];\
\n\
\n#:global ipddns\
\n\
\n:if (\$ipddns != \$currentIP) do={\
\n:log info (\"DynuDDNS: IP-Dynu = \$ipddns\")\
\n:log info (\"DynuDDNS: IP-Fresh = \$currentIP\")\
\n:log info \"DynuDDNS: Update IP needed, Sending UPDATE...!\"\
\n:global str \"/nic/update\?hostname=\$ddnshost&myip=\$currentIP\"\
\n:log info \"currentIP is \$currentIP\"\
\n/tool fetch address=api.dynu.com src-path=\$str mode=http user=\$ddnsuse\
r password=\$ddnspass dst-path=(\"/Dynu.\".\$ddnshost)\
\n:delay 1\
\n:global str [/file find name=\"Dynu.\$ddnshost\"];\
\n/file remove \$str\
\n:global ipddns \$currentIP\
\n:log info (\"DynuDDNS: IP updated to \$currentIP!\")\
\n} else={\
\n:log info (\"DynuDDNS: No change needed\");\
\n}"
/tool graphing interface
add
/tool mac-server
/tool mac-server mac-winbox
lan layout.pdf (21.2 KB)
