Hello. I’d like to request help with my Hap AX Lite lte6, without internet after reset, and starting without config.
I’ve flashed the router several times, and have always selected starting without config to learn how to set it up step by step. Currently, I have ether1 as primary, and lte1 as backup. ether1 has distance of 1. As for lte1, I don’t recall setting it anywhere, but if I remember correctly, so as long as ether1 has distance of 1, lte1 becomes backup.
Now, I tried to unplug ether1, and only have lte1 with sim. Ether2-4 are bridged. I don’t get any internet when connected to ether2-4.
Is there anything to set for lte1? Aside from inserting the sim? I also don’t see lte1 when I try DHCP Client. I wanted for it to get IP address.
[admin@MikroTik] > ip route print Flags: D - DYNAMIC; A - ACTIVE; c - CONNECT Columns: DST-ADDRESS, GATEWAY, ROUTING-TABLE, DISTANCE DST-ADDRESS GATEWAY ROUTING-TABLE DISTANCE DAc 192.168.1.0/24 bridge main
