help with hotspot
hi, i have a hotspot configure on a rb1100AH all is working well, i have a point to point link to another location using rb912 with 23dbi antenna, on the other end of the link, hotspot keep disconnecting after login and asking users to relogin.
any help on how to solve this please?
Make schema from your network pleace
I have the same issue, please explain in details that how I can do this.
Can you be more specific about the time involved? Does it log out the client immediately after the login or after a few minutes?
I recommend you enable debug logging in the hotspot router.
/system logging
add topics=hotspot,debug action=memory
That might tell you why the clients are being logged out.
hi
i have fixed this problem. i only removed address per mac (made it blank) and that solves it.
thanks
