Hi there all I hope you are all well I am needing some help please I am having the following issue with Apple users:
I have a cpasman server on my main gateway that has 7 or so other CAP AC XL devices connected to it all these are on the 192.168.1.xxx range and when I connect with my android or windows based device everything is fine however when I connect an apple device it almost always gets a 192.168.0.xxx range IP of which nothing attached to the network has that IP address range attached to it am I missing something in my configuration ?
Sometimes when I switch off randomized MAC address it gets a correct address assigned by the dhcp server. and more info when the apple device connects it dosent automatically disconnect but they dont get internet.
So first thing is to post your configuration from the capsman controller. Without that it’s hard to say what is wrong.
Appologies please see config
2025-05-26 12:27:09 by RouterOS 7.12.1
software id = EEZ4-6C94
model = RB750Gr3
serial number = HEC08SP4AS3
add fast-forward=no name="bridge1-Champs PC"
add name=bridge2
set [ find default-name=ether1 ] name="ether1 WAN"
set [ find default-name=ether2 ] name="ether2 To Switch"
set [ find default-name=ether3 ] name="ether3 To Champs"
set [ find default-name=ether4 ] name="ether4 Champs PC"
set [ find default-name=ether5 ] name="ether5 Graham hotel network"
/caps-man configuration
add country=etsi datapath.bridge=bridge2 installation=outdoor mode=ap name=
cfg1 security.authentication-types=wpa-psk,wpa2-psk ssid="Graham Hotel"
/interface pppoe-client
add add-default-route=yes disabled=no interface="ether1 WAN" name=pppoe-out1
use-peer-dns=yes user=is.grahamhotel.fff
/interface lte apn
add name=dhcp_pool0 ranges=192.168.1.50-192.168.1.254
add name=dhcp_pool1 ranges=192.168.2.80-192.168.2.180
add address-pool=dhcp_pool0 bootp-support=dynamic interface=bridge2
lease-time=10m name=default
add address-pool=dhcp_pool1 interface="ether3 To Champs" lease-time=10m name=
dhcp1
/port
set 0 name=serial0
/routing table
add fib name=route_guests
add fib name=route_champs
add fib name="Guest internet"
add fib name="Grahamhotel telkom line"
/caps-man manager
set enabled=yes
/caps-man manager interface
add disabled=no interface="ether2 To Switch"
/caps-man provisioning
add action=create-dynamic-enabled master-configuration=cfg1
add bridge="bridge1-Champs PC" ingress-filtering=no interface=
"ether4 Champs PC"
add bridge=bridge2 ingress-filtering=no interface="ether2 To Switch"
/ipv6 settings
/interface ovpn-server server
set auth=sha1,md5
add address=192.168.1.1/24 interface=bridge2 network=192.168.1.0
add address=192.168.2.254/24 interface="ether3 To Champs" network=192.168.2.0
add address=192.168.4.1/29 interface="ether5 Graham hotel network" network=
192.168.4.0
/ip dhcp-client
add add-default-route=no interface="bridge1-Champs PC"
add address=192.168.1.0/24 gateway=192.168.1.1
add address=192.168.2.0/24 gateway=192.168.2.254
add action=accept chain=forward protocol=tcp src-address=192.168.16.0/24
src-port=7892
/ip firewall mangle
add action=mark-routing chain=prerouting new-routing-mark=route_guests
passthrough=no src-address=192.168.1.0/24
add action=mark-routing chain=prerouting new-routing-mark=route_champs
passthrough=yes src-address=192.168.2.0/24
passthrough=yes src-address=192.168.3.0/24
add action=mark-routing chain=prerouting new-routing-mark="Guest internet"
passthrough=yes src-address=192.168.4.0/24
add action=mark-packet chain=prerouting new-packet-mark="Internet Packets"
passthrough=yes src-address=!192.168.0.0/16
add action=mark-packet chain=prerouting dst-address=!192.168.0.0/16
new-packet-mark="Internet Packets" passthrough=yes
add action=accept chain=prerouting dst-address=192.168.0.0/16 src-address=
192.168.0.0/16
"Grahamhotel telkom line" passthrough=yes src-address=192.168.4.2
add action=masquerade chain=srcnat out-interface=pppoe-out1
add action=masquerade chain=srcnat out-interface="bridge1-Champs PC"
add action=masquerade chain=srcnat src-address=192.168.4.2
add action=netmap chain=dstnat dst-port=1723 in-interface=pppoe-out1
protocol=tcp to-addresses=192.168.4.2 to-ports=1723
protocol=udp to-addresses=192.168.4.2 to-ports=1723
add action=netmap chain=dstnat dst-port=1701 in-interface=pppoe-out1
protocol=udp to-addresses=192.168.4.2 to-ports=1701
protocol=tcp to-addresses=192.168.4.2 to-ports=1701
add action=netmap chain=dstnat dst-port=4500 in-interface=pppoe-out1
protocol=tcp to-addresses=192.168.4.2 to-ports=4500
protocol=udp to-addresses=192.168.4.2 to-ports=4500
add action=netmap chain=dstnat dst-port=500 in-interface=pppoe-out1 protocol=
udp to-addresses=192.168.4.2 to-ports=500
tcp to-addresses=192.168.4.2 to-ports=500
add action=netmap chain=dstnat in-interface=pppoe-out1 protocol=gre
add disabled=no dst-address=192.168.16.0/24 gateway="bridge1-Champs PC"
scope=10
add disabled=no dst-address=0.0.0.0/0 gateway=pppoe-out1
/routing bfd configuration
add disabled=no interfaces=all min-rx=200ms min-tx=200ms multiplier=5
/system clock
set time-zone-name=Africa/Johannesburg
/system identity
set name="Ghotel Main"
/system note
set show-at-login=no
