I do not have a diagram of what I want , so I will TRY to describe it…
Eth1 Static Address 69.x.x.200/24 Gateway 69.x.x.1
I want to pass ALL Traffic to 2 other routers with the same address…of 69.x.x.200/24 , BUT , I want to use WInbox to get into MT Eth1 to shut off and turn on Eth2 or Eth3 depending on which router we want using that address.
This is to remotely switch between to systems using the same Exterior static address of 69.x.x.20/24 …i hope that the MT can have the Static IP on Eth1 and a rule can be made for it to grab port 8291 winbox and pass all else to eith interface when enabled.
I realize there my be conflict if both interfaces are enabled at the same time , but this the way we want to do it.
So, WAN ip passed through to two interfaces, only one enabled at a time, with Winbox available on the wan for admin of the MT…
Possible?
