Help with ipsec, android and mtu
Hi all !
I’m new into mikrotik and need some help.
I just configured a ipsec tunnel with nordvpn in my mikrotik router but I do have some problems.
I can’t use videostreaming sites, like netflix from my android devices, it’s working fine from ipad’s and windows, but not android.
I was first thinking it was some kind of DNS problem, because I can use sites like https://www.dnsleaktest.com/ when I press the extended test button I get no results.
So I’ve been fiddeling around with dns settings, but no luck. I can browse the web, listening to audio streams and so on, but no video, not even youtube.
Then someone mentioned MTU, and I was exploring that…
So I was trying to ping my phone from my windows comuter and it seemes like the value should be 1472, if I go higher i can’t ping the phone…
But now? What do I do now? what should I change, and where should I change it ?
