Help With Isolating WiFi SSID with VLAN
Probably a noobie question. Any insight is appreciated.
I have 2 Mikrotik devices, one acts as a router and DHCP server and the other acts as wifi AP.
My current home setup
I’m trying to get WLAN3 on vlan 999, and get response from DHCP server on the other device. Currently I’m getting stuck at waiting for DHCP lease. The rest of the network is working perfectly fine.
My configurations on both devices.
# model = CRS305-1G-4S+
add admin-mac=74:4D:28:B7:42:78 auto-mac=no comment=defconf name=bridge_LAN \
    vlan-filtering=yes
add name=bridge_WAN
set [ find default-name=sfp-sfpplus1 ] auto-negotiation=no name=SFP1
set [ find default-name=sfp-sfpplus2 ] auto-negotiation=no name=SFP2
set [ find default-name=sfp-sfpplus3 ] auto-negotiation=no name=SFP3
set [ find default-name=sfp-sfpplus4 ] name=SFP4
/interface vlan
add interface=SFP2 name=vlan999 vlan-id=999
add name=WAN
add name=LAN
add name=dhcp2 ranges=192.168.0.0/24
add name=dhcp ranges=192.168.0.0/24
add name="dhcp pool" ranges=192.168.99.0/24
add name=dhcp_pool1 ranges=192.168.99.1-192.168.99.254
add address-pool=dhcp disabled=no interface=bridge_LAN name=dhcp2
add address-pool=dhcp_pool1 disabled=no interface=vlan999 name=server1
/user group
set full policy="local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,passw\
    ord,web,sniff,sensitive,api,romon,dude,tikapp"
add bridge=bridge_LAN comment=defconf interface=ether1
add bridge=bridge_WAN comment=defconf disabled=yes interface=SFP1
add bridge=bridge_LAN comment=defconf interface=SFP2
add bridge=bridge_LAN comment=defconf interface=SFP3
add bridge=bridge_LAN comment=defconf interface=SFP4
add bridge=bridge_LAN interface=*8
/interface bridge vlan
add bridge=bridge_LAN tagged=SFP2 vlan-ids=1
add bridge=bridge_LAN tagged=SFP2 vlan-ids=999
add interface=SFP1 list=WAN
add interface=bridge_LAN list=LAN
add interface=bridge_WAN list=LAN
add address=192.168.0.10/16 interface=ether1 network=192.168.0.0
add address=192.168.88.1/16 interface=ether1 network=192.168.0.0
/ip cloud
set update-time=no
/ip dhcp-client
add disabled=no interface=SFP1
add address=192.168.0.0/16 dns-server=8.8.8.8,1.1.1.1 gateway=192.168.0.10 \
    netmask=16
set allow-remote-requests=yes cache-size=8192KiB max-concurrent-queries=1000 \
    max-concurrent-tcp-sessions=200 servers=8.8.8.8,1.1.1.1
/ip dns static
add address=8.8.8.8 name=google
add address=1.1.1.1 name=cloudflare
/ip firewall address-list
add address=192.168.0.1-192.168.255.254 list=allowed_to_router
add address=0.0.0.0/8 comment=RFC6890 list=not_in_internet
add address=172.16.0.0/12 comment=RFC6890 list=not_in_internet
add address=192.168.0.0/16 comment=RFC6890 list=not_in_internet
add address=10.0.0.0/8 comment=RFC6890 list=not_in_internet
add address=169.254.0.0/16 comment=RFC6890 list=not_in_internet
add address=127.0.0.0/8 comment=RFC6890 list=not_in_internet
add address=224.0.0.0/4 comment=Multicast list=not_in_internet
add address=198.18.0.0/15 comment=RFC6890 list=not_in_internet
add address=192.0.0.0/24 comment=RFC6890 list=not_in_internet
add address=192.0.2.0/24 comment=RFC6890 list=not_in_internet
add address=198.51.100.0/24 comment=RFC6890 list=not_in_internet
add address=203.0.113.0/24 comment=RFC6890 list=not_in_internet
add address=100.64.0.0/10 comment=RFC6890 list=not_in_internet
add address=240.0.0.0/4 comment=RFC6890 list=not_in_internet
add address=192.88.99.0/24 comment="6to4 relay Anycast [RFC 3068]" list=\
    not_in_internet
add action=drop chain=input icmp-options=8:0-255 in-interface=!bridge_LAN log=\
    yes protocol=icmp
add action=accept chain=input comment="default configuration" connection-state=\
    established,related
add action=accept chain=input src-address-list=allowed_to_router
add action=accept chain=input dst-address=192.168.0.10 log=yes src-address=\
    192.168.0.15
add action=accept chain=forward log=yes src-address=192.168.0.15
add action=drop chain=input log=yes
add action=fasttrack-connection chain=forward comment=FastTrack \
add action=accept chain=forward comment="Established, Related" \
    "Drop tries to reach not public addresses from LAN" dst-address-list=\
    not_in_internet in-interface=bridge_LAN log=yes log-prefix=!public_from_LAN \
    out-interface=!bridge_LAN
    "Drop incoming packets that are not NATted" connection-nat-state=!dstnat \
    connection-state=new in-interface=SFP1 log=yes log-prefix=!NAT
    "Drop incoming from internet which is not public IP" in-interface=SFP1 log=\
    yes log-prefix=!public src-address-list=not_in_internet
    "Drop packets from LAN that do not have LAN IP" in-interface=bridge_LAN \
    log=yes log-prefix=LAN_!LAN src-address=!192.168.0.0/16
add action=drop chain=input dst-port=53 in-interface=SFP1 log=yes protocol=udp
add action=drop chain=input dst-port=53 in-interface=SFP1 log=yes protocol=tcp
add action=drop chain=forward comment="Drop invalid" connection-state=invalid \
    log=yes log-prefix=invalid
add action=drop chain=forward log=yes src-address=192.168.0.18
add action=masquerade chain=srcnat out-interface=SFP1
add distance=1 gateway=192.168.0.10
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh address=192.168.0.0/16
set api disabled=yes
set winbox address=192.168.0.0/16
set api-ssl disabled=yes
/ip ssh
set strong-crypto=yes
/system clock
set time-zone-name=America/Vancouver
/system ntp client
set enabled=yes primary-ntp=209.115.181.110 secondary-ntp=149.56.121.17
/system routerboard settings
set boot-os=router-os
/tool bandwidth-server
set enabled=no
/tool mac-server
/tool mac-server mac-winbox
/tool mac-server ping
set enabled=no
# model = RBD53iG-5HacD2HnD
add fast-forward=no name=LAN_Bridge vlan-filtering=yes
add authentication-types=wpa2-psk disable-pmkid=yes eap-methods="" management-protection=\
    allowed mode=dynamic-keys name="WiFi Profile" supplicant-identity=""
add authentication-types=wpa2-psk disable-pmkid=yes mode=dynamic-keys name="Guest WiFi" \
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-g/n channel-width=20/40mhz-Ce country=canada2 \
    disabled=no frequency=2422 mode=ap-bridge security-profile="WiFi Profile" ssid=MyWifi \
    wps-mode=disabled
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=20/40/80mhz-Ceee country=\
    canada2 disabled=no mode=ap-bridge security-profile="WiFi Profile" ssid=MyWifi5GHz \
    wps-mode=disabled
add disabled=no keepalive-frames=disabled mac-address=4A:8F:5A:A0:31:C2 master-interface=\
    wlan1 multicast-buffering=disabled name=wlan3 security-profile="Guest WiFi" ssid=\
    Guest WiFi vlan-id=999 vlan-mode=use-tag wds-cost-range=0 wds-default-cost=0 wps-mode=\
    disabled
add bridge=LAN_Bridge interface=wlan1
add bridge=LAN_Bridge interface=wlan2
add bridge=LAN_Bridge interface=ether2
add bridge=LAN_Bridge interface=ether3
add bridge=LAN_Bridge interface=ether4
add bridge=LAN_Bridge interface=ether5
add bridge=LAN_Bridge interface=ether1
add bridge=LAN_Bridge frame-types=admit-only-vlan-tagged interface=wlan3 pvid=999
add bridge=LAN_Bridge tagged=ether1 untagged=wlan3 vlan-ids=999
add bridge=LAN_Bridge tagged=ether1 untagged=ether2,wlan1,wlan2 vlan-ids=1
set servers=8.8.8.8,1.1.1.1
/system clock
