I’m having 2 WAN, load balancing PCC and it’s work well. WAN1 is using PPPoE and WAN2 is using static IP.
Now i have one PPTP VPN in my office and i want to load balancing between WAN1 and PPTP VPN.
But VPN need to go through WAN2.
When i connect to VPN, it’s connected but traffic not go through VPN.
I don’t know how to force VPN using only WAN2.
I need some help. Sorry for my bad English.
This is diagram. it’s maybe help you understand my situation
Hi, as i remember correctly PPTP initial communication goes thru port 1723, so maybe mangle and route packages of that port to your WAN2 are possible solution.
Regards
Marcus
Can you explain more? because i’m newbie in routeros.
Here are my config:
/ip cloud
set ddns-enabled=yes
add address=192.168.88.0/24 gateway=192.168.88.1
set allow-remote-requests=yes cache-size=5000KiB max-udp-packet-size=512 \
servers=8.8.8.8
add action=passthrough chain=unused-hs-chain comment=\
"place hotspot rules here" disabled=yes
/ip firewall mangle
add action=mark-connection chain=input in-interface=WAN1 new-connection-mark=\
WAN1_conn
add action=mark-connection chain=input in-interface=WAN2 new-connection-mark=\
WAN2_conn
add action=mark-connection chain=input disabled=yes in-interface=pptp-out1 \
new-connection-mark=pptp_conn
add action=mark-routing chain=output connection-mark=WAN1_conn \
new-routing-mark=to_WAN1
add action=mark-routing chain=output connection-mark=WAN2_conn \
new-routing-mark=to_WAN2
add action=mark-routing chain=output connection-mark=pptp_conn disabled=yes \
new-routing-mark=to_pptp
add chain=prerouting dst-address=192.168.0.0/24 in-interface=Local
add action=mark-connection chain=prerouting dst-address-type=!local \
in-interface=Local new-connection-mark=WAN1_conn \
per-connection-classifier=both-addresses-and-ports:3/0
in-interface=Local new-connection-mark=WAN2_conn \
per-connection-classifier=both-addresses-and-ports:3/1
per-connection-classifier=both-addresses-and-ports:4/0
per-connection-classifier=both-addresses-and-ports:4/1
add action=mark-routing chain=prerouting connection-mark=WAN1_conn \
in-interface=Local new-routing-mark=to_WAN1
add action=mark-routing chain=prerouting connection-mark=WAN2_conn \
in-interface=Local new-routing-mark=to_WAN2
add action=masquerade chain=srcnat out-interface=WAN1
add action=masquerade chain=srcnat out-interface=WAN2
add check-gateway=ping distance=1 gateway=WAN1 routing-mark=to_WAN1
add check-gateway=ping distance=1 gateway=192.168.0.1 routing-mark=to_WAN2
add check-gateway=ping distance=2 gateway=192.168.0.1
When i add these lines, i can’t go to internet
add add-default-route=yes connect-to=abc.xyz disabled=no mrru=\ 1600 name=pptp-out1 password=vpn user=vpn
add action=mark-connection chain=input in-interface=pptp-out1 \ new-connection-mark=pptp_conn
add action=mark-routing chain=output connection-mark=pptp_conn \new-routing-mark=to_pptp
add action=masquerade chain=srcnat out-interface=pptp-out1
add distance=1 gateway=pptp-out1 routing-mark=to_pptp
Any helps? ![]()
