Long time browsing the forum, first time posting. I have a lot more experience with cisco than mikrotik, but i find mikrotik to be very interesting and i have few devices to work with now.
My biggest issue is with mangle (at least i think so), im using RB1100. I will try to explain my problem in details (unable to post configuration for privacy reasons, client requires it…)
I’m happy to listen to any suggestion.
Situation is as follows:
On RB1100 on interface (interface 6) which is addressed 192.168.1.1/24 they have connected their switches and the rest of their network, they have their windows server as DHCP.
For this network they have two mangle rules (both prerouting, mark routing, passtrough) one is marked server communication and the other one client communication. They also have two routes one for each mangle rule, route is 0.0.0.0/0 with interface 5 as gateway (Interface 5 is WAN). They also use masquarade.
And everything is working peachy…
This is where it gets complicated (for me)
They made new VLAN on mikrotik with new mangle rule (also prerouting, mark routing, passtrough) and new routing mark - wifivlan, for that VLAN mikrotik is DHCP, address is 192.168.200.1/24. There is also new route 0.0.0.0/0 with routing mark wifivlan, gateway is also interface 5 (WAN).
So communication in network 192.168.1.0 is ok, communication in network 192.168.200.0 is also ok, but these two networks cant communicate between each other and they have resources on network 1.0 which they need to access from theri wifi → network 200.0…
I have tried:
Creating new mangle rule and putting it on top (rule was: prerouting, accept, dst and src networks were the networks in question)
Creating ip route rule with action lookup only in table main
Any suggestions?
Thanks in advance ![]()
