Help with mantbox ax 15s
I need all the help I can get setting up 3 mAntbox ax 15s access points mounted on tower.
No capman cause the dishes use different capsman.
I need step by step for complete setup of the 3 access points.
I am new to all this mikrotik.
Router is ccr 1009-7G-1c-1s+pc.
Dishes are lhgg-60ad kit.
Can someone please help me set up the 3 access points mounted so I have WiFi outside.
Two options:
  1. Get a consultant:
    https://mikrotik.com/consultants?category=consultants
  2. Learn yourself, with a little help from your forum friends.
As you didn't supply any relevant information, you won't get any answers. Provide a map of the situation, your preferred settings (bandwidth/frequencies/etc.) and you current settings (/export file=anynameyoulike minus serial and any other private info).
Is this another install, very similar to this one you already posted about?
and then you abandoned?
However - only for the record - the two dishes are NOT involved in CAPSMAN at all, they are (should be) a wireless replacement of an ethernet cable (hence some kits are called "wireless wire") they are (should be) a completely transparent (L2 and L3) link and nothing else.
You have to imagine to setup the CCR 1009 connected to a switch via ethernet and then the three Mantbox connected to the switch.
Once everything works, you remove the ethernet cable and replace it with the pair of lhgg-60ad dishes and nothing changes.
However CAPSMAN is not strictly speaking needed, it is only convenient to make settings in a centralized way and it helps with roaming.
