I am having a hard time with the MIB on The Dude 4.0beta3. I have loaded the following MIBs below but when I go to the tree I only see DLSW-MIB0 – 1, IEEE8021-PAE-MIB – 110, IEEE8023-LAB-MIB – 85, and IEEE802dot11-MIB --218. All of the other ones are grayed out and I don’t see them in the tree. Why cannot I see them and look into those mibs. I have a Cisco ASA 8.2(1) that when I snmpwalk. I only get the number on the OID and simple OID. I don’t get a description which is what I am trying to accomplish. Thanks in advance, Josh
Example
OID SIMPLE OID TYPE VALUE
iso.3.6.1.2.1.1.1.0 1.3.6.1.2.1.1.1.0 octet string Cisco Adapative Security Appliance Version 8.2(1)
Installed MIBS
RFC1213-MIB.mib
IF-MIB.mib
SNMPv2-MIB.mib
Mikrotik.mib
SNMPv2-MIB-EXT-01.mib
SNMPv2-SMI.mib
SNMPv2-TC[rfc2579].mib
IANAifType-MIB.mib
ADSL2-LINE-MIB.mib
ADSL-DMT-LINE-MIB.mib
ADSL-LINE-EXT-MIB.mib
ADSL-LINE-MIB.mib
ADSL-TC-MIB.mib
AGENTX-MIB.mib
APM-MIB.mib
APPC-MIB.mib
APPLETALK-MIB.mib
APPLICATION-MIB.mib
APPN-DLUR-MIB.mib
APPN-MIB.mib
APPN-TRAP-MIB.mib
ATM2-MIB.mib
ATM-ACCOUNTING-INFORMATION-MIB.mib
ATM-MIB.mib
ATM-TC-MIB.mib
BGP4-MIB.mib
BRIDGE-MIB.mib
CHARACTER-MIB.mib
CLNS-MIB.mib
COFFEE-POT-MIB.mib
COPS-CLIENT-MIB.mib
DECNET-PHIV-MIB.mib
DIAL-CONTROL-MIB.mib
DIFF-SERV-MIB.mib
DIRECTORY-SERVER-MIB.mib
DISMAN-EVENT-MIB.mib
DISMAN-LOOKUP-MIB.mib
DISMAN-NSLOOKUP-MIB.mib
DISMAN-PING-MIB.mib
DISMAN-SCHEDULE-MIB.mib
DISMAN-SCRIPT-MIB.mib
DISMAN-TRACEROUTE-MIB.mib
DLSW-MIB.mib
DNS-RESOLVER-MIB.mib
DNS-SERVER-MIB.mib
DOCS-BPI2-MIB.mib
DOCS-BPI-MIB.mib
DOCS-CABLE-DEVICE-MIB.mib
DOCS-CABLE-DEVICE-TRAP-MIB.mib
DOCS-IF-EXT-MIB.mib
DOCS-IF-MIB.mib
DOCS-QOS-MIB.mib
DOCS-SUBMGT-MIB.mib
DOT12-IF-MIB.mib
DOT12-RPTR-MIB.mib
DRAFT-MSDP-MIB.mib
DS0BUNDLE-MIB.mib
DS0-MIB.mib
DS1-MIB.mib
DS3-MIB.mib
DSA-MIB.mib
DSMON-MIB.mib
DVMRP-MIB.mib
EBN-MIB.mib
ENTITY-EXTENSIONS-MIB.mib
ENTITY-MIB.mib
ETHER-CHIPSET-MIB.mib
EtherLike-MIB.mib
EXP-DOCS-CABLE-DEVICE-MIB.mib
FCMGMT-MIB.mib
FDDI-SMT73-MIB.mib
FIBRE-CHANNEL-FE-MIB.mib
Finisher-MIB.mib
FLOW-METER-MIB.mib
FRAME-RELAY-DTE-MIB.mib
FR-ATM-PVC-SERVICE-IWF-MIB.mib
FRF16-MFR-MIB-EXP.mib
FRNETSERV-MIB.mib
H221-MIB.mib
H320ENTIRY-MIB.mib
H320TERMINAL-MIB.mib
H323-GATEKEEPER-MIB.mib
H323GW-MIB.mib
H323TERMINAL-MIB.mib
HCNUM-TC.mib
HC-RMON-MIB.mib
HOST-RESOURCES-MIB.mib
HOST-RESOURCES-TYPES.mib
HOST-RESOURCES-V2-MIB.mib
HPR-IP-MIB.mib
HPR-MIB.mib
IANA-ADDRESS-FAMILY-NUMBERS-MIB.mib
IANA-RTPROTO-MIB.mib
IANATn3270eTC-MIB.mib
IEEE802dot11-MIB.mib
IEEE8021-PAE-MIB.mib
IEEE8023-LAG-MIB.mib
IF-INVERTED-STACK-MIB.mib
IGMP-MIB.mib
IGMP-STD-MIB.mib
INET-ADDRESS-MIB.mib
INTEGRATED-SERVICES-GUARANTEED-MIB.mib
INTEGRATED-SERVICES-MIB.mib
INTERFACETOPN-MIB.mib
INT-SERV-GUARANTEED-MIB.mib
INT-SERV-MIB.mib
IPATM-IPMC-MIB.mib
IP-FORWARD-MIB.mib
IP-MIB.mib
IPMROUTE-MIB.mib
IPMROUTE-STD-MIB.mib
IPOA-MIB.mib
IPSEC-ISAKMP-IKE-DOI-TC.mib
IPSEC-MIB.mib
IPSEC-SA-MON-MIB.mib
IPsecT1-MIB.mib
IPV6-ICMP-MIB.mib
IPV6-MIB.mib
IPV6-TC.mib
IPV6-TCP-MIB.mib
IPV6-UDP-MIB.mib
ISCSI-MIB.mib
ISDN-MIB.mib
ISIS-MIB.mib
MAU-MIB.mib
MESSAGE-TRACKING-MIB.mib
MIOX25-MIB.mib
MIP-MIB.mib
Modem-MIB.mib
MPLS-LSR-MIB.mib
MPLS-TE-MIB.mib
MPLS-VPN-MIB.mib
MSDP-MIB.mib
MTA-MIB.mib
MULTI-MEDIA-REG-TC.mib
NETWORK-SERVICES-MIB.mib
NHRP-MIB.mib
OSPF-MIB.mib
OSPF-TRAP-MIB.mib
OSPFV3-MIB.mib
PARALLEL-MIB.mib
P-BRIDGE-MIB.mib
PerfHist-TC-MIB.mib
PIM-MIB.mib
PMCAPS-MIB.mib
POLICY-MANAGEMENT-MIB.mib
PPP-BRIDGE-NCP-MIB.mib
PPP-IP-NCP-MIB.mib
PPP-LCP-MIB.mib
PPP-SEC-MIB.mib
Printer-MIB.mib
PTOPO-MIB.mib
Q-BRIDGE-MIB.mib
QOS-BRIDGE-MIB.mib
RADIUS-ACC-CLIENT-MIB.mib
RADIUS-ACC-SERVER-MIB.mib
RADIUS-AUTH-CLIENT-MIB.mib
RADIUS-AUTH-SERVER-MIB.mib
RDBMS-MIB.mib
RFC1066-MIB-INTERPRETATION.mib
RFC-1215.mib
RFC1215-TRAP.mib
RFC1229-MIB.mib
RFC1230-MIB.mib
RFC1231-MIB.mib
RFC1232-MIB.mib
RFC1233-MIB.mib
RFC1243-MIB.mib
RFC1248-MIB.mib
RFC1252-MIB.mib
RFC1253-MIB.mib
RFC1269-MIB.mib
RFC1271-MIB.mib
RFC1284-MIB.mib
RFC1285-MIB.mib
RFC1286-MIB.mib
RFC1304-MIB.mib
RFC1315-MIB.mib
RFC1316-MIB.mib
RFC1317-MIB.mib
RFC1318-MIB.mib
RFC1353-MIB.mib
RFC1354-MIB.mib
RFC1381-MIB.mib
RFC1382-MIB.mib
RFC1389-MIB.mib
RFC1398-MIB.mib
RFC1406-MIB.mib
RFC1407-MIB.mib
RFC1414-MIB.mib
RIPv2-MIB.mib
RMON2-MIB.mib
RMON-MIB.mib
RS-232-MIB.mib
RSVP-MIB.mib
RTP-MIB.mib
SCSPATMARP-MIB.mib
SCSP-MIB.mib
SCTP-MIB.mib
SIP-COMMON-MIB.mib
SIP-MIB.mib
SIP-MIB-SMI.mib
SIP-REGISTRAR-MIB.mib
SIP-SERVER-MIB.mib
SIP-TC.mib
SIP-UA-MIB.mib
SLAPM-MIB.mib
SMON-MIB.mib
SNA-NAU-MIB.mib
SNA-SDLC-MIB.mib
SNMP-COMMUNITY-MIB.mib
SNMP-FRAMEWORK-MIB.mib
SNMP-MPD-MIB.mib
SNMP-NOTIFICATION-MIB.mib
SNMP-PROXY-MIB.mib
SNMP-REPEATER-MIB.mib
SNMP-TARGET-MIB.mib
SNMP-USER-BASED-SM-3DES-MIB.mib
SNMP-USER-BASED-SM-MIB.mib
SNMP-USM-DH-OBJECTS-MIB.mib
SNMPv2-CONF.mib
SNMPv2-M2M-MIB.mib
SNMPv2-OPS.mib
SNMPv2-PARTY-MIB.mib
SNMPv2-PDU.mib
SNMPv2-TC.mib
SNMPv2-TC-EXT-01.mib
SNMPv2-TM.mib
SNMPv2-USEC-MIB.mib
SNMP-VIEW-BASED-ACM-MIB.mib
SONET-MIB.mib
SOURCE-ROUTING-MIB.mib
SSPM-MIB.mib
SYSAPPL-MIB.mib
TCP-MIB.mib
TelcoReturnCABLE-DEVICE-MIB.mib
TN3270E-MIB.mib
TN3270E-RT-MIB.mib
TOKENRING-MIB.mib
TOKEN-RING-RMON-MIB.mib
TOKENRING-STATION-SR-MIB.mib
TPM-MIB.mib
TUNNEL-MIB.mib
UDP-MIB.mib
UPS-MIB.mib
USB-MIB.mib
VRRP-MIB.mib
WWW-MIB.mib
XGCP-MIB.mib
ACCOUNTING-CONTROL-MIB.mib
CISCO-CRYPTO-ACCELERATOR-MIB.mib
CISCO-ENTITY-FRU-CONTROL-MIB.mib
CISCO-FIREWALL-MIB.mib
CISCO-IPSEC-FLOW-MONITOR-MIB.mib
CISCO-MEMORY-POOL-MIB.mib
CISCO-PROCESS-MIB.mib
CISCO-REMOTE-ACCESS-MONITOR-MIB.mib
CISCO-SMI.mib
CISCO-SYSLOG-MIB.mib
CISCO-UNIFIED-FIREWALL-MIB.mib
SNMP-USM-MIB.mib
SNMP-VACM-MIB.mib
ALTIGA-GLOBAL-REG.mib
ALTIGA-LBSSF-STATS-MIB.mib
ALTIGA-MIB.mib
ALTIGA-SSL-STATS-MIB.mib
