I was messing around trying to understand recursive routes but after getting everything setup I can seem to get my vlans to work properly. The internet just goes in and out but for sure the internet connection is working well. I dont know if im missing something in the mangle rules or really where else to look. If someone could check my config and let me know if anything sticks out id really appreciate it.
thank you ..
MMM MMM KKK TTTTTTTTTTT KKK
MMMM MMMM KKK TTTTTTTTTTT KKK
MMM MMMM MMM III KKK KKK RRRRRR OOOOOO TTT III KKK KKK
MMM MM MMM III KKKKK RRR RRR OOO OOO TTT III KKKKK
MMM MMM III KKK KKK RRRRRR OOO OOO TTT III KKK KKK
MMM MMM III KKK KKK RRR RRR OOOOOO TTT III KKK KKK
MikroTik RouterOS 7.6 (c) 1999-2022 https://www.mikrotik.com/
Press F1 for help
[admin@MikroTik] > export
# nov/14/2022 19:08:14 by RouterOS 7.6
# software id = 7XHG-9DN7
# model = RB760iGS
# serial number = E1F20DBE9019
add admin-mac=08:55:31:FE:65:6C auto-mac=no comment=defconf ingress-filtering=\
no name=bridge vlan-filtering=yes
/interface vlan
add interface=bridge name=200 vlan-id=200
add interface=bridge name=Test23 vlan-id=23
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface lte apn
/ip hotspot profile
add name=dhcp_pool1 ranges=192.168.200.2-192.168.200.254
add name=dhcp_pool2 ranges=192.168.200.2-192.168.200.254
add name=dhcp_pool3 ranges=192.168.200.10-192.168.200.254
add name=dhcp_pool4 ranges=192.168.23.10-192.168.23.250
add address-pool=default-dhcp interface=bridge name=defconf
add address-pool=dhcp_pool3 interface=200 name=dhcp1
add address-pool=dhcp_pool4 interface=Test23 name=dhcp2
/port
set 0 name=serial0
/routing table
add fib name=to_ISP1
add fib name=to_ISP2
add bridge=bridge comment=defconf ingress-filtering=no interface=ether3
add bridge=bridge comment=defconf ingress-filtering=no interface=ether5
add bridge=bridge comment=defconf ingress-filtering=no interface=sfp1
add bridge=bridge ingress-filtering=no interface=ether4
/ipv6 settings
/interface bridge vlan
add bridge=bridge tagged=bridge,ether4 vlan-ids=200
add bridge=bridge tagged=bridge,ether5 vlan-ids=23
add interface=ether2 list=WAN
/interface ovpn-server server
set auth=sha1,md5
192.168.88.0
add address=192.168.200.1/24 interface=200 network=192.168.200.0
add address=192.168.23.1/24 interface=Test23 network=192.168.23.0
/ip dhcp-client
add add-default-route=no comment=defconf interface=ether1
add add-default-route=no interface=ether2
add address=192.168.23.0/24 dns-server=8.8.8.8 gateway=192.168.23.1
add address=192.168.200.0/24 dns-server=8.8.8.8,1.1.1.1 gateway=192.168.200.1
set allow-remote-requests=yes
/ip dns static
add action=accept chain=input
established,related,untracked
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
add action=drop chain=forward comment="defconf: drop invalid" connection-state=\
invalid
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" \
connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
/ip firewall mangle
add action=mark-connection chain=output connection-mark=no-mark \
connection-state=new new-connection-mark=ISP1_conn out-interface=ether1 \
passthrough=yes
add action=mark-routing chain=output connection-mark=ISP1_conn \
new-routing-mark=to_ISP1 out-interface=ether1
add action=mark-connection chain=output connection-mark=ISP2_conn \
connection-state=new new-connection-mark=ISP2_conn out-interface=ether2 \
passthrough=yes
add action=mark-routing chain=output connection-mark=ISP2_conn \
new-routing-mark=to_ISP2 out-interface=ether2
add action=masquerade chain=srcnat comment="defconf: masquerade" ipsec-policy=\
out,none out-interface-list=WAN
add action=masquerade chain=srcnat out-interface=ether2
add comment="Monitor Internet 1" disabled=no distance=1 dst-address=1.0.0.1/32 \
gateway=192.168.2.1 pref-src="" routing-table=main scope=10 \
suppress-hw-offload=no target-scope=10
add comment="Monitor Internet 2" disabled=no distance=2 dst-address=4.2.2.2/32 \
gateway=172.25.1.1 pref-src="" routing-table=main scope=10 \
add check-gateway=ping comment="Default Route" disabled=no distance=1 \
dst-address=0.0.0.0/0 gateway=1.0.0.1 pref-src=0.0.0.0 routing-table=main \
scope=30 suppress-hw-offload=no target-scope=11
add check-gateway=ping comment="BackUp Route" disabled=no distance=2 \
dst-address=0.0.0.0/0 gateway=4.2.2.2 pref-src=0.0.0.0 routing-table=main \
/system clock
set time-zone-name=America/New_York
/system ntp client
set enabled=yes
/system ntp client servers
add address=40.119.6.228
/tool mac-server
/tool mac-server mac-winbox
/tool romon
set enabled=yes
[admin@MikroTik] >
