Help with NAT (IPsec VPN)
We’ve got 3 Routers.
  1. Router 1 has IPsec connection with Router 2. Clients connect from Router 1 to Router 2 server. 172.22.50.0/24 → 172.120.100.22
  2. Router 3 has IPsec connection with Router 1. Clients from Router 3 connect to Router 1 server. 172.190.20.0/24 → 172.22.50.200
If Router 3 hasn’t direct IPsec with Router 2? How clients from Router 3 via Router 1 can reach Router Router 2 ? What NAT rules should I create on both routers so that 172.190.20.0/24 would reach server 172.120.100.22?
Tried different rules but without luck. I would really appreciate any help. Thanks.
I still have no solution :frowning: Anyone? Smb said I need to make some route rules, but I know routes aren’t used in IPsec. For example clients from router 1 connects without issues to router 2 without any route rules.
The solution has been posted so many times already: do not use direct IPsec tunnels, use GRE or IPIP tunnels over IPsec transport.
Setup /30 addresses on the tunnel, and set BGP peers to eachother. Put the local networks in BGP networks.
Everything will just work without having to fight with NAT.
Unfortunately we cannot change connection method at this point, IPsec tunnel. There should be a solution in this case too.
