I can get from PC 2 to main router, but I cant get from PC1 to router2 and AP3. Can you help if it is possible and how to setup it to be it able?
I need it for configration of router2 and APs behind him.
You need to configure a routing protocol (OSPF or RIP2) on Router1 and Router2.
It should be done manually or not?
Yes It can be done manually:
In router1:
# DST-ADDRESS PREF-SRC G GATEWAY DIS INTERFACE
1 A S 10.13.55.0/24 r 192.168.10.6 1 Local
In every router you need to add network where you want to get, and which way(ip).
