Just found out that Mikrotik changed the Vlan Setup Routeros.
After trying for a couple of Days, could someone show me an Example how to realize this with the new Setup:
Having trunk ports and access ports is fine, but I am struggling with having different Trunk Ports.
ether1 having all vlans (11, 5 , 6 , 7, 10), ether3 should be a trunk port with an untagged vlan 11 (tagged: 5, 6 , 7, 10), and ether 4 should only send 2 tagged vlans (7, 10).
eth1: is the uplink trunk port to the router with all Vlans available
eth3: is a link to a ubiquiti ap, with 4 different SSID’s, managemnt vlan is 11 and therefore needs to be untagged for ubiquiti. (Called General Port in other switches, not trunk)
eth4: is a link to an Voip System, and for security reasons should only contain vlan 7 & 10
You cant untag 11 to the AP.
It needs to be tagged.
How you deal with it will be at the AP software or config.
The AP will decide which WLANs to untag…
