HELP with Nstreme
Hi Everyone,
I have 2 boxes configured with Nstreme on the same mast. The boxes stopped pushing traffic whenever the 2 of them are powered on. They start to push traffic if either of them is powered off.
What are the possible causes of this behaviour and how can it be solved?
PS: The boxes are; Dynadish and MANT 19s. RouterOS - 6.42.11. Frequency - Superchannels
Thank you for your support
Can we get clarification of “stop pushing traffic” ?
  • device(s) shuts down?
  • devices are on but the link(s) fails?
  • devices are on, links are on but data are not transmitted?
  • devices are on, links are on, data are transmitted but nothing is received?
  • any other way to interpret your words?
In addition, what is the relation between your boxes?
  • are they on the same L2 network or completely independent?
  • are they on the same frequency? (superchannel is mode, not a frequency)
  • facing same direction?
Maybe if you share config of both your devices with ****
/export hide-sensitive
, someone might spot the reason (in case if it is caused by misconfiguration)
Also, facing same direction with different frequency; 5550 & 5370
Radio1
/interface wireless
set [ find default-name=wlan1 ] band=5ghz-a/n/ac channel-width=20/40/80mhz-eCee
disabled=no frequency=5370 frequency-mode=superchannel mode=bridge
nv2-security=enabled ssid=xxxxxx wireless-protocol=nstreme
/interface wireless nstreme
set wlan1 enable-nstreme=yes
Radio 2
/interface wireless
disabled=no frequency=5550 frequency-mode=superchannel mode=bridge
