Help with P/Forwarding to Extender by Winbox
Hi there,
I have a master RB433 with OS4.10 installed, setup as a hotspot and wds to an extender and working fine, both can communicate and ping each other.
Master - WAN IP: 192.168.1.10, Wlan IP (wds to extender): 10.5.50.1
Extender - Wlan IP (wds to master): 10.5.50.2
I try to use winbox access to the extender via the master by using p/forwarding but unsuccessfully.
I added a rules on the master:
/ip firewall nat add action=dst-nat chain=dstnat comment=“forward Winbox” disabled=no protocol=tcp dst-port=8292 dst-address=192.168.1.10 to-addresses=10.5.50.2 to-ports=8291
I open up a winbox and try with the address 192.168.1.10:8292 but it doesn’t work.
I been searching many forum but still cant works it out ><"
Anyone can help?
Thanks.
If you are connecting from device that is on the same network where device to which you are trying to connect is located, then it is not going to work, because response from the device comes directly bypassing the route and NAT rule.
