Please take a look on my configuration. I have 3 Public interfaces and 3 Local interfaces. I’d like to get all the Local interfaces to have a personalized load balancing.
Do I have to disable masquerade?
All IP’s are reachable but I’m struggling with the routing, currently all works through Wizibiz50bridge, but when I try to run the command set, all stops working.
WAN Interfaces:
9 R Orcon10bridge bridge 1500 1596
10 R Telecom20bridge bridge 1500 1596
13 R Wizbiz50bridge bridge 1500 1596
LAN Interfaces:
2 R ether3 ether 1500 1600
18 R ResidentialVLANbridge bridge 1500 1596
19 R PublicVLANbridge bridge 1500 1596
IP Adresses:
0 X ;;; added by setup
192.168.3.254/24 192.168.3.0 192.168.3.255 Orcon10bridge
1 ;;; added by setup
202.xxx.xxx.40/24 202.xxx.xxx.0 202.xxx.xxx.255 Wizbiz50bridge
2 ;;; added by setup
192.168.1.253/24 192.168.1.0 192.168.1.255 ether3
3 202.xxx.xxx.250/32 202.xxx.xxx.250 202.xxx.xxx.250 Wizbiz50bridge
4 ;;; hotspot network
10.5.50.1/24 10.5.50.0 10.5.50.255 PublicVLANbridge
5 202.xxx.xxx.200/32 202.xxx.xxx.200 202.xxx.xxx.200 Wizbiz50bridge
6 10.0.0.253/32 10.0.0.253 10.0.0.253 Telecom20bridge
7 192.168.3.253/32 192.168.3.253 192.168.3.253 Orcon10bridge
Current Ip Routes:
# DST-ADDRESS PREF-SRC GATEWAY DISTANCE
0 A S 0.0.0.0/0 202.174.163.254 1
1 ADC 10.0.0.253/32 10.0.0.253 Telecom20bridge 0
2 ADC 10.5.50.0/24 10.5.50.1 PublicVLANbridge 0
3 ADC 192.168.1.0/24 192.168.1.253 ether3 0
4 ADC 192.168.3.253/32 192.168.3.253 Orcon10bridge 0
5 ADC 202.xxx.xx3.0/24 202.xxx.xx3.40 Wizbiz50bridge 0
6 ADC 202.xxx.xx5.200/32 202.xxx.xx5.200 Wizbiz50bridge 0
7 ADC 202.xxx.xx5.250/32 202.xxx.xx5.250 Wizbiz50bridge 0
What I am trying to do:
/ip firewall mangle
add action=accept chain=prerouting comment="Outside the Load Balancing" disabled=no dst-address-list=loopback in-interface=ether3
add action=mark-connection chain=input comment="Tag new incoming connection Wizbiz" connection-state=new disabled=no in-interface=Wizbiz50bridge new-connection-mark=Wizbiz passthrough=yes
add action=mark-connection chain=input comment="Tag new incoming connection Orcon" connection-state=new disabled=no in-interface=Orcon10bridge new-connection-mark=Orcon passthrough=yes
add action=mark-connection chain=input comment="Tag new incoming connection Telecom" connection-state=new disabled=no in-interface=Telecom20bridge new-connection-mark=Telecom passthrough=yes
add action=mark-connection chain=prerouting comment="Tag incoming connections established Wizbiz" connection-state=established disabled=no in-interface=Wizbiz50bridge new-connection-mark=Wizbiz passthrough=yes
add action=mark-connection chain=prerouting comment="Tag incoming connections established Orcon" connection-state=established disabled=no in-interface=Orcon10bridge new-connection-mark=Orcon passthrough=yes
add action=mark-connection chain=prerouting comment="Tag incoming connections established Telecom" connection-state=established disabled=no in-interface=Telecom20bridge new-connection-mark=Telecom passthrough=yes
add action=mark-connection chain=prerouting comment="Tag related incoming connection Wizbiz" connection-state=related disabled=no in-interface=Wizbiz50bridge new-connection-mark=Wizbiz passthrough=yes
add action=mark-connection chain=prerouting comment="Tag related incoming connection Orcon" connection-state=related disabled=no in-interface=Orcon10bridge new-connection-mark=Orcon passthrough=yes
add action=mark-connection chain=prerouting comment="Tag related incoming connection Telecom" connection-state=related disabled=no in-interface=Telecom20bridge new-connection-mark=Telecom passthrough=yes
add action=mark-routing chain=output comment="Incoming connection mark Wizbiz" connection-mark=Wizbiz disabled=no new-routing-mark=static-Wizbiz passthrough=no
add action=mark-routing chain=output comment="Incoming connection mark Orcon" connection-mark=Orcon disabled=no new-routing-mark=static-Orcon passthrough=no
add action=mark-routing chain=output comment="Incoming connection mark Telecom" connection-mark=Telecom disabled=no new-routing-mark=static-Telecom passthrough=no
lan side
add action=mark-connection chain=prerouting comment="PCC 3 way non local traffic - option 1" connection-state=new disabled=no dst-address-type=!local in-interface=ether3 new-connection-mark=Wizbiz_pcc_conn passthrough=yes per-connection-classifier=both-addresses:3/0
add action=mark-connection chain=prerouting comment="PCC 3 way non local traffic - option 2" connection-state=new disabled=no dst-address-type=!local in-interface=ether3 new-connection-mark=Orcon_pcc_conn passthrough=yes per-connection-classifier=both-addresses:3/1
add action=mark-connection chain=prerouting comment="PCC 3 way non local traffic - option 3" connection-state=new disabled=no dst-address-type=!local in-interface=ether3 new-connection-mark=Telecom_pcc_conn passthrough=yes per-connection-classifier=both-addresses:3/2
add action=mark-connection chain=prerouting comment="PCC 3 way non local traffic established - option 1" connection-state=established disabled=no dst-address-type=!local in-interface=ether3 new-connection-mark=Wizbiz_pcc_conn passthrough=yes per-connection-classifier=both-addresses:3/0
add action=mark-connection chain=prerouting comment="PCC 3 way non local traffic established - option 2" connection-state=established disabled=no dst-address-type=!local in-interface=ether3 new-connection-mark=Orcon_pcc_conn passthrough=yes per-connection-classifier=both-addresses:3/1
add action=mark-connection chain=prerouting comment="PCC 3 way non local traffic established - option 3" connection-state=established disabled=no dst-address-type=!local in-interface=ether3 new-connection-mark=Telecom_pcc_conn passthrough=yes per-connection-classifier=both-addresses:3/2
add action=mark-connection chain=prerouting comment="PCC 3 way non local traffic related- option 1" connection-state=related disabled=no dst-address-type=!local in-interface=ether3 new-connection-mark=Wizbiz_pcc_conn passthrough=yes per-connection-classifier=both-addresses:3/0
add action=mark-connection chain=prerouting comment="PCC 3 way non local traffic related- option 2" connection-state=related disabled=no dst-address-type=!local in-interface=ether3 new-connection-mark=Orcon_pcc_conn passthrough=yes per-connection-classifier=both-addresses:3/1
add action=mark-connection chain=prerouting comment="PCC 3 way non local traffic related- option 3" connection-state=related disabled=no dst-address-type=!local in-interface=ether3 new-connection-mark=Telecom_pcc_conn passthrough=yes per-connection-classifier=both-addresses:3/2
add action=mark-routing chain=prerouting comment="FWD to mark PCC - Option 1" connection-mark=Wizbiz_pcc_conn disabled=no new-routing-mark=Wizbiz passthrough=yes
add action=mark-routing chain=prerouting comment="FWD to mark PCC - Option 2" connection-mark=Orcon_pcc_conn disabled=no new-routing-mark=Orcon passthrough=yes
add action=mark-routing chain=prerouting comment="FWD to mark PCC - Option 3" connection-mark=Telecom_pcc_conn disabled=no new-routing-mark=Telecom passthrough=yes
add check-gateway=arp comment="Telecom - Distance 1" disabled=no distance=1 dst-address=0.0.0.0/0 gateway=Telecom20bridge routing-mark=Telecom
add check-gateway=arp comment="Orcon - Distance 1" disabled=no distance=1 dst-address=0.0.0.0/0 gateway=Orcon10bridge routing-mark=Orcon
add check-gateway=arp comment="Wizbiz - Distance 1" disabled=no distance=1 dst-address=0.0.0.0/0 gateway=Wizbiz50bridge routing-mark=Wizbiz
add check-gateway=arp comment="Wizbiz - Distance 2" disabled=no distance=2 dst-address=0.0.0.0/0 gateway=Orcon10bridge routing-mark=Wizbiz
add check-gateway=arp comment="Orcon - Distance 2" disabled=no distance=2 dst-address=0.0.0.0/0 gateway=Telecom20bridge routing-mark=Orcon
add check-gateway=arp comment="Telecom - Distance 2" disabled=no distance=2 dst-address=0.0.0.0/0 gateway=Wizbiz50bridge routing-mark=Telecom
add check-gateway=arp comment="Wizbiz - Distance 3" disabled=no distance=3 dst-address=0.0.0.0/0 gateway=Telecom20bridge routing-mark=Wizbiz
add check-gateway=arp comment="Orcon - Distance 3" disabled=no distance=3 dst-address=0.0.0.0/0 gateway=Wizbiz50bridge routing-mark=Orcon
add check-gateway=arp comment="Telecom - Distance 3" disabled=no distance=3 dst-address=0.0.0.0/0 gateway=Orcon10bridge routing-mark=Telecom
add check-gateway=arp comment="Default Route - Distance 1" disabled=no distance=1 dst-address=0.0.0.0/0 gateway=Wizbiz50bridge
add check-gateway=arp comment="Default Route - Distance 2" disabled=no distance=3 dst-address=0.0.0.0/0 gateway=Telecom20bridge
add check-gateway=arp comment="Default Route - Distance 3" disabled=no distance=2 dst-address=0.0.0.0/0 gateway=Orcon10bridge
add check-gateway=arp comment="Static Route - Wizbiz" disabled=no distance=1 dst-address=0.0.0.0/0 gateway=Wizbiz50bridge routing-mark=Wizbiz
add check-gateway=arp comment="Static Route - Orcon" disabled=no distance=2 dst-address=0.0.0.0/0 gateway=Orcon10bridge routing-mark=Orcon
add check-gateway=arp comment="Static Route - Telecom" disabled=no distance=3 dst-address=0.0.0.0/0 gateway=Telecom20bridge routing-mark=Telecom
/ip firewall address-list
add address=200.155.80.0-200.155.255.255 comment=BRADESCO disabled=no list=loopback
add address=200.220.186.0/24 comment=BRADESCO disabled=no list=loopback
add address=200.220.178.0/24 comment=BRADESCO disabled=no list=loopback
add address=64.38.29.0/24 comment=RapidShare disabled=no list=loopback
add address=208.69.32.0/24 comment="" disabled=no list=loopback
add address=208.67.217.0/24 comment="" disabled=no list=loopback
add address=201.7.178.0/24 comment="" disabled=no list=loopback
add address=201.7.176.0/24 comment="" disabled=no list=loopback
add address=200.159.128.0/24 comment=BRADESCO disabled=no list=loopback
add address=201.7.176.0/20 comment="Vdeos - Globo" disabled=no list=loopback
add address=208.84.247.0/24 comment="Vdeos - terratv" disabled=no list=loopback
add address=200.154.56.0/24 comment="Vdeos - terratv" disabled=no list=loopback
add address=200.201.160.0/24 comment="Caixa Economica Federal" disabled=no list=loopback
add address=200.201.166.0/24 comment="" disabled=no list=loopback
add address=200.201.173.0/24 comment="" disabled=no list=loopback
add address=200.201.174.0/24 comment="" disabled=no list=loopback
add address=200.141.207.3 comment=Detran disabled=no list=loopback
add address=85.17.216.46 comment=www.easy-share.com disabled=no list=loopback
add address=200.222.8.9 comment=Detran disabled=no list=loopback
What I should add? any help much appreciated.
