Help with performance test results...
Looking at the test results shown in the attachment- are these results fungible across ports if you are not using all of the ports on the system at the same time? Maybe a specific example would be "if I’m switching a stream of 64B packets from port 1 to port 5, and there’s NO OTHER traffic on the router… what is the expected performance? Is more than the 542kpps quoted here because the forwarding capacity is centralized rather than per port? I have assumptions based on other platforms I’ve worked on but I figure it’s just easier to ask :slight_smile:
