I have the following working perfectly in Delphi. But i don’t know how to run the same in PHP.
How do I do the following using PHP API:
Eg: 1
/ppp/secret/remove
=numbers=testuser
Eg: 2
/ppp/secret/add
=name=testuser
=password=testpass
=remote-address=10.1.1.1
Eg: 3
/ppp/secret/print
=count-only
Eg: 4
/queue/simple/print
=count-only
Eg: 5
/queue/simple/remove
=numbers=1,2,3
Eg: 6
/queue/simple/add
=parent=testparent
=name=childtest
=max-limit=4000/4000
=limit-at=800/800
=target=192.1.1.2
Eg: 7
/queue/simple/add
=name=testmulti
=target=21.1.1.1/32,14.1.2.2/32,14.1.2.3/32,14.1.2.4/32
=max-limit=4096/8192
=burst-limit=10024/10024
=burst-time=10/15
Eg: 8
/ip/hotspot/user/print
=.proplist=.id,name,mac-address,uptime
Using my PHP client:
<?php
require_once 'PEAR2_Net_RouterOS-1.0.0b6.phar';
use PEAR2\Net\RouterOS;
$util = new RouterOS\Util($client = new RouterOS\Client('192.168.88.1', 'admin', 'password'));
$util->setMenu('/ppp secret');
$util->remove('testuser');
$util->add(
array(
'name' => 'testuser',
'password' => 'testpass',
'remote-address' => '10.1.1.1'
$secretCount = $util->count();
$util->setMenu('/queue simple');
$queueCount = $util->count();
$util->remove(1, 2, 3);
$util->add(
array(
'parent' => 'testparent',
'name' => 'childtest',
'max-limit' => '4000/4000',
'limit-at' => '800/800',
'target' => '192.1.1.2'
array(
'name' => 'testmulti',
'target' => '21.1.1.1/32,14.1.2.2/32,14.1.2.3/32,14.1.2.4/32',
'max-limit' => '4096/8192',
'burst-limit' => '10024/10024',
'burst-time' => '10/15'
echo '<table>';
foreach ($util->setMenu('/ip hotspot user')->getAll(array('.proplist' => '.id,name,mac-address,uptime')) as $user) {
echo '<tr>';
foreach ($user as $prop => $value) {
echo '<th>' . htmlspecialchars($prop) . '</th><td>' . htmlspecialchars($value) . '</td>';
echo '</tr>';
echo '</table>';
Im getting this error. the protected array.
Also the parent is created but why does this happen
Fatal error: Uncaught PEAR2\Net\RouterOS\RouterErrorException: Router returned error when adding items in phar://C:/mikrotikweb/PEAR2_Net_RouterOS-1.0.0b6.phar/PEAR2_Net_RouterOS-1.0.0b6/src/PEAR2/Net/RouterOS/Util.php:867 Stack trace: #0 C:\mikrotikweb\tst2.php(23): PEAR2\Net\RouterOS\Util->add(Array, Array) #1 {main} Response collection: Array ( [0] => PEAR2\Net\RouterOS\Response Object ( [unrecognizedWords:protected] => Array ( ) [_type:PEAR2\Net\RouterOS\Response:private] => !trap [attributes:protected] => Array ( [message] => input does not match any value of parent ) [_tag:PEAR2\Net\RouterOS\Message:private] => ) [1] => PEAR2\Net\RouterOS\Response Object ( [unrecognizedWords:protected] => Array ( ) [_type:PEAR2\Net\RouterOS\Response:private] => !done [attributes:protected] => Array in phar://C:/mikrotikweb/PEAR2_Net_RouterOS-1.0.0b6.phar/PEAR2_Net_RouterOS-1.0.0b6/src/PEAR2/Net/RouterOS/Util.php on line 867
key part from this error message is
Apparently, you have no queue named “testparent”, and thus the add() call in “/queue simple” fails. Add “testparent” first, and then this call will work.
You can handle errors like these more gracefully by surrounding the statement(s) with try-catch, e.g.
try {
$util->add(
array(
array(
} catch (RouterOS\RouterErrorException $e) {
echo 'Router failed with the following first error: ' . $e->getResponses()->getAllOfType(RouterOS\Response::TYPE_ERROR)->getProperty('message');
