Hello. I’m trying to setup port forwarding for the camera system we are using and have tried various things but to no avail.
I’m thinking something in the firewall rules is where I’m messing up but am a total noob when it comes to that.
Would be grateful if anyone could point me in the right direction?
> /ip address print detail
0 ;;; Air2Data LAN IP
address=192.168.100.1/24 network=192.168.100.0 broadcast=192.168.100.255
interface=ether2 actual-interface=ether2
1 address=192.168.99.1/24 network=192.168.99.0 broadcast=192.168.99.255
interface=ether3 actual-interface=ether3
2 D address=192.168.254.1/24 network=192.168.254.0 broadcast=192.168.254.255
interface=ether1 actual-interface=ether1
> /ip route print detail
0 ADS dst-address=0.0.0.0/0 gateway=192.168.254.254
gateway-status=192.168.254.254 reachable ether1 distance=0 scope=30
target-scope=10
1 S dst-address=0.0.0.0/0 gateway=192.168.254.254
gateway-status=192.168.254.254 reachable ether1 distance=1 scope=30
target-scope=10
2 ADC dst-address=192.168.99.0/24 pref-src=192.168.99.1 gateway=ether3
gateway-status=ether3 reachable distance=0 scope=10
3 ADC dst-address=192.168.100.0/24 pref-src=192.168.100.1 gateway=ether2
gateway-status=ether2 reachable distance=0 scope=10
4 ADC dst-address=192.168.254.0/24 pref-src=192.168.254.1 gateway=ether1
gateway-status=ether1 reachable distance=0 scope=10
> /ip firewall export
# jun/26/2012 16:37:28 by RouterOS 4.11
# software id = 104L-TQMS
set enabled=yes generic-timeout=10m icmp-timeout=10s tcp-close-timeout=10s tcp-close-
wait-timeout=10s \
tcp-established-timeout=1d tcp-fin-wait-timeout=10s tcp-last-ack-timeout=10s tcp-
syn-received-timeout=5s \
tcp-syn-sent-timeout=5s tcp-syncookie=no tcp-time-wait-timeout=10s udp-stream-
timeout=3m udp-timeout=10s
add action=passthrough chain=unused-hs-chain comment="place hotspot rules here"
disabled=yes
disabled=yes
add action=masquerade chain=srcnat comment="" disabled=no
[b]add action=dst-nat chain=dstnat comment="GV800 - HTTP" disabled=no dst-
address=192.168.254.1 dst-port=60001 \
protocol=tcp to-addresses=192.168.99.51 to-ports=60001
add action=dst-nat chain=dstnat comment="GV800 - Command" disabled=no dst-
address=192.168.254.1 dst-port=\
60002 protocol=tcp to-addresses=192.168.99.51 to-ports=60002
add action=dst-nat chain=dstnat comment="GV800 - Data" disabled=no dst-
address=192.168.254.1 dst-port=60003 \
protocol=tcp to-addresses=192.168.99.51 to-ports=60003
add action=dst-nat chain=dstnat comment="GV800 - Audio" disabled=no dst-
address=192.168.254.1 dst-port=60004 \
protocol=tcp to-addresses=192.168.99.51 to-ports=60004
add action=dst-nat chain=dstnat comment="GV800 - RPB Server" disabled=no dst-
5066 protocol=tcp to-addresses=192.168.99.51 to-ports=5066[/b]
/ip firewall service-port
set ftp disabled=no ports=21
set tftp disabled=no ports=69
set irc disabled=no ports=6667
set h323 disabled=no
set sip disabled=no ports=5060,5061
set pptp disabled=no
