Help with ppp on-up, on-down script maybe a bug?
Hi.
I need to do this:
When a PPPoE client connect to server the script add its interface to
/ip upnp interface
I wrote this on-UP:
:ip upnp interfaces add interface=$interface type=internal
And it works…
The problem is remove that interface when the client disconnect…
I wrote this on-DOWN
:ip upnp interfaces remove [/ip upnp interfaces find interface=<$interface>]
or
:ip upnp interfaces remove [/ip upnp interfaces find interface=$interface]
It doesn’t work…
in interface list there are an “unknown” entry for every disconnection
Please help, also workaround is good ex. a way for remove all interface called unknown
[/ip upnp interfaces find interface=unknown] <-doesnt work :frowning:
Any suggestion please?
If i type /ip upnp interface print i obtain:
[admin@Server] /ip upnp interfaces> print
Flags: X - disabled, D - dynamic
INTERFACE TYPE FORCED-IP
0 *F00008 internal
1 ether1 external
2 *F00009 internal
3
0 and 2 are dead interfaces, there is a way to remove all entry that start to *F0 ?
Good evening, try using the command:
on-down:
:ip upnp interfaces remove [find interface=$user]
