Help with RB493AH
Guys,
I need help in configuring my RB493AH,
I need to change the IP of my RB493AH to 10.10.10.254 netmask 255.255.254.0 &
i need to enable NAT but no DHCP enable & i want to act eth0 as WAN port.
Please help configure may RB493AH
I think default configuration on RB750g should do the trick, change the ip adress, ether1 i set to wan interface, switching on the rest. Nat enabled, the only thing you need to fix is the ip adress and disable dhcp. I don’t have that unit with me now, but i could download the config tomorrow.
Or, you could login to the web interface and select most of it from there.
Check out the wiki for more information.
Thanks ojsa and can i have the default config of RB750G? also it is possible to create user group in RB493AH called “Postpaid” & “Prepaid”, Postpaid will have a monthly fee while Prepaid use prepaid card to browse the internet.
Guys,
could someone help me configure my RB493AH, I’m new to this router
I want to change the IP address of my RB493Ah to 10.10.10.254 & netmask 255.255.254.0 and use eth1 as WAN and enable NAT but disable DHCP. please help me configure my router base on the picture above.
and last, i should be able to access RB493AH from my Main tower. My dsl modem is auto-connect to my ISP, could someone help me about this config.
even 10.10.10.254 is not pingable from internal network.
Any help will be greatly appreciated.
Hi, I am not as well versed as some of the guys in the forum, but I would be willing to help.
I have had a 493AH for over a year and I believe I can help configure it.
Send me some contact info and I will get in touch.
Don
Thanks, i can’t send private message here.
I just need to enable NAT on ether2 to ether9 because ether1 will act as WAN port and i should be able to ping all that IP.
DSL Modem (dnynamic IP)
ether1: 10.10.10.254 (Gateway)
Private LAN IP:
ether2: 10.10.10.1
ether3: 10.10.10.2
ether4: 10.10.10.3
ether5: 10.10.10.4
ether6: 10.10.10.5
ether7: 10.10.10.6
ether8: 10.10.10.7
ether9: 10.10.10.8
anyway, please contact me at nanflexal@gmail.com
OK. Sent you an email with my phone #. Be happy to help.
Thanks.
