I’m trying to redirect traffic to a external squid proxy.
This image illustrate my config (the image is from another user, but my config is the same): http://forum.mikrotik.com/download/file.php?id=5892
The rule used:
/ip firewall nat add chain=dstnat src-address=10.10.10.0/24 protocol=tcp dst-port=80 action=dst-nat to-addresses=10.10.10.2 to-ports=3128
If i configure the proxy direct in the browser, all works. But with the redirect rule nothing happen, the connection don’t give any error. And nothing is logged in the squid log, is like the connection never hit the proxy itself.
My squid.conf
http_port 3128 transparent
visible_hostname proxy
cache_mem 64 MB
maximum_object_size_in_memory 64 KB
maximum_object_size 512 MB
minimum_object_size 0 KB
cache_swap_low 90
cache_swap_high 95
cache_dir ufs /var/spool/squid 2048 16 256
cache_access_log /var/log/squid/access.log
refresh_pattern ^ftp: 15 20% 2280
refresh_pattern ^gopher: 15 0% 2280
refresh_pattern . 15 20% 2280
acl all src 0.0.0.0/0.0.0.0
acl manager proto cache_object
acl localhost src 127.0.0.1/255.255.255.255
acl SSL_ports port 443 563
acl Safe_ports port 21 80 443 563 70 210 280 488 59 777 901 1025-65535
acl purge method PURGE
acl CONNECT method CONNECT
http_access allow manager localhost
http_access deny manager
http_access allow purge localhost
http_access deny purge
http_access deny !Safe_ports
http_access deny CONNECT !SSL_ports
http_access allow localhost
http_access allow all
