Hi, I’m starting to test OSPF, so I searched for OSPF on website.
I found an example, and I’m trying to make this network:
inthis example: http://www.mikrotik.com/testdocs/ros/2.9/routing/ospf.php?notfound=6&
I know is an old example, but to start I hope it will work…
My doubt is this: if I ping “main_gw” or “to_peer1” from OSPF_peer_1 it works, so I suppose OSPF make the routing operations.
I’m using RB750 devices, so if I want to connect my PC to OSPF_peer_1 on third ethernet port (let’s suppose eth3 IP addres would be 158.110.30.1/24), how can I do to configure RB750 to work correctly with my PC (158.110.30.5)?
Thanks.
