I’m new to MikroTik, just got a hap ac2 yesterday and I have been trying to set some static routes.
I have setup static routes on OpenWRT before, by can’t seem to figure out how to do it in RouterOS.
Image bellow is from OpenwWRT that I would like to replicate in RouterOS.
Thank you very much for your reply.
I’m not familiar with script code, still learning. I have added the routes through winbox terminal, routes are created but still having some issues.
Basically I’m trying to setup the router for smartdnsproxy streaming services.
hAP ac2 6.46.4 Default quick set home ap dual config
LAN: 192.168.7.1
I have PPPoE connection, disabled use peer DNS.
Added IP-> DNS-> DNS1: 154.127.57.224 DNS2: 129.232.164.26, Allow remote routes
Added IP-> DHCP Server->Networks-> set as same DNS servers as above.
Destination IP Address: 8.8.8.8
IP Subnet Mask : 255.255.255.255 (or /32)
Gateway IP: 192.168.7.1
Metric: 1
Interface: any other than WAN (preferably LAN)
Destination IP Address: 8.8.4.4
Metric: 1
Destination IP Address: 45.57.62.0
IP Subnet Mask : 255.255.255.0
Metric: 2
Destination IP Address: 45.57.63.0
Metric: 2
When I ping IP 8.8.8.8 & 8.8.4.4 i still get a reply, it supposed to get a reply from 192.168.7.1: Destination host unreachable.
Also had these configured in OpenWRT
Port Forward:
Traffic Rule:
Can you please advise on how to configure these as well?
I checked what’s smartdnsproxy and it looks like they just provide DNS servers and you configure your devices to use them. I don’t see why would you need to do anything with routes. Correct me if you have some other info.
If it’s like I think, then this is correct (if those addresses are their servers):
Or you can put only 192.168.7.1 (router’s address) there and get a tiny little speedup, because if one client already requested some record, another client will get it from router’s cache if it needs it.
And if you want to prevent clients from bypassing this and using other DNS servers, you can use dstnat and redirect all queries to router:
Without the static routes working properly, when I watch USA Netflix on my nVidia Shield TV, I get error message complaining about proxy or VPN.
My understanding, some android apps have hard coded DNS settings that need to be blocked or redirected.
That’s what those dstnat rules I posted will do. If such device tries to send DNS query to 8.8.8.8, router will redirect it to itself (DNS cache running on router) and it will forward this query to DNS servers configured in IP->DNS.
Their explanation about static routes doesn’t make sense to me. According to my quick test, RouterOS doesn’t seem to like gateway being its own address and route is not active. But even if it was active, it would work only as unusual way to block the query. It would not redirect it anywhere without other config. One way would be same dstnat as I posted. Another would be to assign 8.8.8.8 to router as another address.
Still some issues with Netflix, It works fine on PC but not on my NV Shield TV.
Can you please provide me with an example of this that you mentioned, “Another would be to assign 8.8.8.8 to router as another address.”
And router would see it as local address and wouldn’t send packets with that destionation anywhere else. But don’t do that, it’s ugly trick, it’s not your address. And it’s not really needed anyway, dstnat rules can’t be fooled, if there’s packet going to 8.8.8.8:53, they will catch it. But maybe the device does not use regular DNS on port 53. In that case you can block access using:
Thank you very much for your time and assistance Sob.
Next up on my list to look into is QoS and Bufferbloat issues…Getting C/D ratings on dslreports speedtest…
Hello
That is the question that has been disturbing me about few days.
Basically I’m trying to set up the router for smart DNS proxy streaming services.
