help with RTSP/cameras/Blue Iris
Hello
So I have several cameras by Foscam, Dahua, Lilin and KT&C. They are tied into my NVR blue Iris.
Blue Iris is running on a local PC and it can see all the live streams.
The problem is when I try to use those streams in another applications I can only get a snapshot jpg, I cannot pass on RTSP (h264) or MJPEG streams.
I have tried to port forward 554 via TCP but maybe I did it wrong? Anyone have any advice? I am still learning my way around the Tik, lot more features and involved than my previous hardware so please be kind!
In the past with my older router I just used a free DDNS address, set up a port forward to the BI server (a PC) and it all worked. now I am using the cloud Tik address, still have BI set to the port forward and the BI app works, but the streams themselves do not which makes me suspect its something particular to the cameras and their settings/IP address/rules and not so much my BI server.
I am tearing my hair out, I got family and friends coming for the game tomorrow and just want things working in order as they did prior to me putting in the Tik.
Thanks!
Cameras might have performance problems with providing multiple high definition streams. Or the port speed autonegotiation didn’t work well and link speed is at 10mbits. It is better to get the data from NVR instead of the cameras, if it is able to provide it.
